Need help finding hooks for towing.
The attached picture is from a previous post in this forum many months ago. Does anybody know where to get those hooks?
Thanks in advance.
Thanks in advance.
Just a piece of advice. On a lowered car, forget about driving on the street, the front hooks will scrap everywhere. I've a pair of "U" shape hooks from Autometrics if you want them.
I am/was planning to install them on a 997. I e-mailed autometrics to see if they would work and I haven't heard back yet.
NJ-GT, I am planning to drive my GT3 on the street, and to make sure I understand you correctly, you mean the front hooks will touch ground routinely. I thought they were mounted fairly high at least 6-7 inches from the ground and towards the center of rotation of the wheel, which it would make it even more difficult to scratch, but apparently not.
I am still deciding on how to tow the car if "pulling" on the wheels with a lot of care and love or to grab the chassis down and disable the suspension during the ride. I know there is no hard science either way.
I am leaning towards forgetting the hooks and tying the car down by the wheels, which seems to be the most common way people do it.
Thanks for the hint.
I can tell you about the hooks. There is nowhere to mount them for the front. The rears will work perfectly. The trick to preventing them from hitting is to pre-bend them ONCE only. The rears will never hit though. It's only the fronts that cause problems and since they won't work for the 997 GT-3, that's not a problem.
Another option for the front is to get a "claw" type strap from Home Depot and use the front jacking point to stick the claw into. For the rears, use the Autometrics. This will work very well.
Remember, every possible tie down method has its plusses and minuses. You can decide for yourself what you are comfortable with. I personally don't like the wheels since they rotate during towing and that allows the straps to have some slack. You don't want slack on the straps since that allows the car to develop momentum before the strap stops it. That's alot of force. I would rather attach the straps to the frame so no momentum can develop.
Thanks in advance.
Thanks in advance.
In spite of these issues, these Autometrics hooks seem like the best choice for convenience. The rear hooks do not bottom out but the passenger side causes the tie down strap hook to get close if not touch the main oil line from the engine. I don't want the hook touching it in any way, so I've added a 10K lb carabiner or you can use one of those screw-closed rings. The carabiner is easier to remove when removing the strap. I heard that CDOC has similar tie down points to the Autometrics but they are already pre-bent to 45 degrees.
On another topic about loose bolts: the sway bar nuts. They tend to loossen up and fall of if not checked before every track day. I've purchased a couple of extras for this reason.
