what's the scoop on the techquipment bar?
#33
#38
GT3 player par excellence
most good bars will have a cross bar in the main hoop, thus they should all accept shoulder strap from a 6 pt or 5 pt.
#40
http://e-partssales.com/Merchant2/me...ry_Code=997gt3
#41
997 GT3 Bar
I see that this thread has come back to life. I wrestled with this issue on my GT3 when I got it last spring. I installed the 997 tech bar which performed flawlessly. It also works perfectly with the Hans device and harnesses. I removed the bar this winter, was thinking about a full cage, and then went with the Dassport Bar.
Ryan, I notice that you're going with the Dassport bar. Good Choice. Before you install, I have a trick for the front insertion point bolts. I picked up rocker arm studs from a 427 chevy and used these as the bolts. The advantage is that you can have the bar bolted into the car body, but separately take the lower attachment of the seat belt on and off. If you're interested, I have a few bolts left (eight cylinder engine block - I only used 2 of the bolts). I'll post pics if you guys are interested.
#42
Pics of Dassport Install 997 GT3
Some pics of the install with the rocker arm stud bolt used for insertion of selt belt. This allows me to take off the seat belt to change my seat easily during race season without taking out the bolt that secures the bar. The rocker arm stud bolts pictured are a perfect fit (7/16 - 20 / and seat belt side 7/16 - 14).
#43
Hmmm...According to Suncoast's website, it is not compatible to 5 or 6 pts? Could they be mistaken?
maybe the horizontal bar is too short, i dont know why it won't work, but i defer to their expertise in this matter.
#45
