New Cobalt GT3
#46
Cripes! I rode in Ray's GT3 yesterday... time to start selling off cars so I can get one too
This is a fantastic Porsche! Truely a great track car and daily driver.
The sound of that exhaust in Sport mode is pure *sex*
Congrats to Ray and everyone that gets one of these great cars.
#48
Originally Posted by DreamCarrera
Ray, I LOVE YOUR NEW 3 that is one sweet looking P-Car!!!. Congrats and enjoy her.
I'm really loving this car! I can't stop driving it. I've had it about 6 days and have 400 miles on it now. Other observations:
- The 'Sport' mode does not seem to change the throttle mapping - which is the way I like it.
- Pressing the 'Sport' button does not automatically engage the sport damper setting. They are independent now.
I caught a picture of the two blue ballers, waiting for rumble at the track:
#49
Details
My salesman gave me a "Service Information" booklet on the new GT3. It describes the changes introduced in the new car. Here are some highlights you may have not seen in the press:
- Traction Control (or "Anti-Slip Regulation) is achieved by closing the throttle and reducing ignition timing.
- Engine Drag Torque Control (like on the Carrera GT) will quickly open the throttle if "lateral stability is lost at the rear axle after a downshift." Switching T/C off turns this feature off too.
- Throttle opening has been enlarged from 76mm to 82mm.
- New intake manifold has 2 switchable tuning flaps. They switch at these points:
- under 5400 rpm, both tuning flaps are closed.
- 5400-6350 rpm, small flap open, big flap closed.
- over 6350 rpm, small flap closed, big flap opened
- over 7500 rpm, both flaps are opened
- New exhaust system employs 2 front mufflers and a single rear muffler (as before), but vacuum controlled valves open to by-pass the front mufflers when under heavy load.
- Exhaust system volume grew by .42 cubic feet and weight was reduced by 18.7 lbs compared to the previous model.
- Variocam is infinitely adjustable up to 52 degrees (up from 42 degrees)
- Transmission (G97.90) has oil spray lubrication using pressurized oil, heat exchanger, steel synchro rings in 3, 4, and 5th gear, and shorter ratios in gears 2-6 than the previous GT3.
- Shifter throw is about 15% shorter than 996 GT3, and 33% shorter than standard 997.
- Asymmetric Limited-Slip Differential with lock values of 28% under traction and 40% under deceleration. (996 GT3 was 40% traction, 60% deceleration)
- Many changes to the chassis, including adjustable anti-roll bars (5 way front, 3 way rear), reinforced components for use with racing tires, spring system "compatible with racing springs".
- Front suspension "is the proven front axle concept of the 996 GT3-RS."
- Rear suspension "is basically the same as the regular 997," but with stiffer springs, dampers, and anti-roll bar. Rubber bushings have been replaced with metal bushes (as on the 996 GT3).
- Steering ratio is variable, up to 13.8:1 after 30 deg of turning.
- Brake cooling at the front has been improved with new air spoilers and new air deflection vanes. Brake cooling at the rear axle is the same as the 997 Turbo.
- Brake force distribution has changed. The rear axle has relatively higher braking power. This is supposed to reduce braking distance.
- Brake booster is same as 997 C4S and 997 Turbo (9-inch tandem boosters).
- The rear axle uses 5mm wheel spacers to widen the track.
#54
just heard from the dealer my CB GT3 has arrived after it's euro delivery odessy ...
a note on the rear brake bias on the 997 GT3 ... this pretty much wore out a set of PCCB pads on my car after 50 laps of the nordschleife! sport+sport PASM+TC off ...
you have been warned ...
