need help on ordering specs!
picked all my options today however I wanted your opinions on couple of them.
first some background info. purpose of this car is partial daily driver and track toy. expecting to track as often as I can afford it both timewise and $$$ for fees/tires/gas/oil. Probably translates to ~12-16 track days in a year. I have 5 years experience with track schools, run in advanced group, and I will try my best to take it "easy" considering this is the most expensive car i ever owned.
1. PCCB's - Been beaten to death I know. I specced them. I just feel that I will regret not getting them. I figure if I really don't like them I could sell them for the standard brakes or swap to motorsport steel rotors. I would really like to run 18" track wheels but not sure any 18's will fit over these monsters.
2. Phone Module for PCM - this is for the 90% of the time this car is a street car and I plan on driving it to work often. I'm thinking of dropping this feature though. seems like i either have to figure out how to copy and use a duplicate SIM or pay for an extra phone line just for the car. would rather keep to one number and not mess with forwarding calls.
Okay, have at it! All comments appreciated and also thanks to so many of the people on this board for all the help so far!
other options i have and sure about
xenons - just can't go back to halogens
pcm - i'm horrible at directions, nav is a must
wart - i actually like it....
-jim
-jim
Jim,
from what I understand, you can simply take your SIM card out of your mobile phone and put it into the car phone module. Your existing phone number and stored phone book (if saved on the SIM card and not the phone itself) would transfer to the car so threre is no need to pay for an extra phone line for the car. I thought the price for this option is a bit excessive so I'll rather use my handsfree kit.
I think a car with this price tag should have the Xenons. Same with the PCM. I like the wart as well.
You might want to check out the colored belts to match your brake caliper color to break up the interior a bit. I have now seen the colored instrument dials in person and would advise against them as they are tough to see in daylight. You might also consider the full leather, which gives you the stiching around the instrument panel and more alcantara. Note that the stiching is in grey, so it is already "deviated".
Good luck!
Good luck!
Jim
Duplicate SIM cards is a no brainer - don't sweat it, Joest Do It (as Reinhold says) - believe it or not, the separate handset is worth having, there ARE times when you do not wish to be overheard.
I am in and out of a lot of different cars, I prefer cars with bluetooth capability. In the S8 I can see everything that is on my SIM card without taking it out of my pocket.
By all means order the PCCBs. However, it will be more cost effective to also buy a set of alternative brakes - rotors, callipers, steel lines and Castrol brake fluid. Top of the line brakes based upon iron rotor technology will give you the best bang per buck, particularly if you are using the brakes fairly seriously on your track days.
Probably 6 piston monobloc callipers in front will be most effective if you drive high speed courses, low speed tracks are not as hard on the brakes, compare the size and cost of the pads, against other alternatives, also select rotors which have plenty of meat in them and consider fitting the Cup air scoops when at the track.
Under the right 18 inch rims you can fit 380mm rotors and 6 piston callipers.
You can offset the weight of iron rotors, to a degree, by using Ti wheel bolts.
R+C
R+C
Originally Posted by Frank 993 C4S
Jim,
Good luck!
Good luck!
full leather was the other option i was considering but ultimately decided the car looks good enough w/o it.
pccb's i'm still on the fence though. 8800 could get you some nice track wheels which would have the same effect on reduced unsprung weight. probably enough left over for the roll bar.
Originally Posted by MJSpeed
^+1. Enjoy your ride!! BTW are you getting an RS or GT3? Oh and what colour will it be?
I ended up specing pccbs, and I've probably been one of the most vocal ones on here about their pros and cons (my intent was to get the facts out in the open on their benefits and limitations).
I justified them in my own odd way, but saying, well the RS cost 20k more in orange paint, so in settling for the 3, I'll roll the dice on ceramics. LOL.
