Gallardo vs 997 GT3
Originally Posted by DJ 996
A 997TT will eat the Gallardo alive! LOL![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
Originally Posted by Lambo Review
Steering, high-speed stability, traction and chassis balance are all superior to that of Porsche’s 911 Turbo. Even on the wet, treacherous roads of the North York Moors it re-mained composed and utterly thrilling. In short, the Gallardo is tremendous – a car that gives you the drama without the drawbacks.
Originally Posted by 997 Turbo Review
The Turbo is savagely fast in any gear at any revs. But with the stability control off, driving at the limit requires skill, as the 911 is harder work than the Lamborghini Gallardo; it’s heavier and slower to react. Understeer is an issue, and when balanced out with the throttle, any resulting oversteer calls for quick steering inputs to correct.
Still, the original question was the 997 GT-3 vs Gallardo. For track, the GT3 will probably be better, or at least more fun.
here's the data from http://www.track-challenge.com/main_e.asp
with the 996 RS. short track equal, G slower at ring..
Gallardo GT3 RS
Manufacturer Lamborghini Porsche
Testing Date 12/2003 3/2004
Engine 4961 cccm, 10 Zyl , 40 V 3600 cccm, 6 Zyl , 24 V
Power 500 PS (368 KW) @ 7800/min 381 PS (280 KW) @ 7400/min
Torque 510 Nm @ 4500/min 385 Nm @ 5000/min
Transmission 2 (6) 0 (6)
Weight 1613 Kg 1373 Kg
Weight / BhP 3,2 Kg / PS 3,6 Kg/ PS
0 - 100 Km/h 4 s 4,2 s
0 - 200 Km/h 13 s 13,5 s
0 - 200-0 Km/h 18 s 18,2 s
Top Speed
309 Km/h 306 Km/h
80 - 120 Km/h 4.Gear 4,2 s 4,6 s
100 - 0 Km/h hot 34,4 m , 11,2 m/s 34,1 m , 11,3 m/s
Transverse Acceleration 1,35 g 1,4 g
Slalom Course 36 / 110m 131 / 147 Km/h 134 / 150 Km/h
Round Time Nuerburgring 7.52 min 7.47 min
Round Time Hockenheim 1.11,8 min 1.11,8 min
G reliability is known to be very good, virtually no issues. makes you wonder why 2 yr warranty.
i almost bought one:
4wd great in malibu, but car is heavier than gt3
04 egears can be unpdated to 06 and run well
service in LA is marginal, need to go to OC
looks are ??? nice in black but that means dirty black for me.
no real storage space and luggage room, really a daily commuter only
Gallardo GT3 RS
Top Speed
309 Km/h 306 Km/h
Also, keep in mind the 2006+ GT3 has better gearing, more HP, and revised suspension (...and revised aerodynamics, and revised brakes, and revised tires, and revised wheels, and revised electronics, and revised ROOF
![hiha](https://rennlist.com/forums/graemlins/roflmao.gif)
I only meant that the comparo from track-challenge.com was from 2003 apparently.
I think the performance increase of the 06+ Gallardo is greater than the performance increase of the 997 GT3. The new GT3 is probably only slightly faster around a track than the 996 GT3 RS. It's in the same ballpark. The 2006+ G is quite a bit better than the 2005 G.
i thought only RS got lower gearing, and gt3 satyed too tall???? please confirm
996 GT3 / 996 GT3 RS: Ring & Pinion Gear: 3.44:1
Gear Ratio---Gear --- RPM drop on upshift --- Max Speed at 8,200 rpm (8,000 in 5th and 6th)
3.82------------1st---------------------------------46 mph
2.15 -----------2nd ----------4600 rpm----------82 mph
1.56 -----------3rd-----------5950 rpm----------114 mph
1.21 -----------4th-----------6350 rpm----------147 mph
1.00 -----------5th-----------6800 rpm----------173 mph
0.85 ---------- 6th ----------6800 rpm----------203 mph (8,000 rpm)
997 GT3 / 997 GT3 RS: Ring & Pinion Gear: 3.44:1
Gear Ratio---Gear --- RPM drop on upshift --- Max Speed at 8,400 rpm (8,000 in 5th and 6th)
3.82------------1st---------------------------------50 mph
2.26 -----------2nd ----------4950 rpm----------85 mph
1.64 -----------3rd-----------6100 rpm----------116 mph
1.29 -----------4th-----------6600 rpm----------148 mph
1.06 -----------5th-----------6900 rpm----------172 mph
0.92 ---------- 6th ----------6950 rpm----------198 mph
Both the 997 GT3 and 997 GT3 RS have the same gears and R&P. Let's see how the 997 GT3/GT3 RS compare to the 996 GT3/GT3 RS.
many thanks NJ. what does this mean practically? will the 997's feel noticeably lower geared in daily use? my main complaint on the 996 gt3 was gears too tall for canyon slamming.
watt,
It means that you'll feel the 997 GT3 and RS long geared as well. If you want a car with good gearing, the F360CS and F430 are great examples, and the Z06 a good example until 4th gear, because 5th and 6th are way off on both the C5 and C6.
On the 997 GT3, other than the 350 rpm improvement between 1st and 2nd gear (slightly noticeable), all the other gears are closer by just 100 rpm to 250 rpm. That's hardly noticeable.
Let's say your canyon enthusiast driving ranges from 55 mph to 140 mph. In the old car you were driving in 2nd, 3rd and 4th, in the new car you will be driving in 2nd, 3rd and 4th as well.
My car uses a 4.00:1 Ring and Pinion Gear, and stock gears. Under the same 55 mph to 140 mph canyon driving range, my shift points driving in 3rd, 4th and 5th are closer compared to the 997 GT3 by 250 rpm and 200 rpm. Compared to the 996 GT3 in the same speed range, my car is geared closer by 400 rpm and 450 rpm.
997 GT3 + RSR 4.00:1 R&P = Lots of fun
watt,
there are a lot of people posting about the Gallardo's performance, who have NEVER driven one, or if they have they are not sufficiently skilled to get the potential out of the car.
Sorry, the Gallardo is faster from A to B than the 997 GT3 and the 997 Turbo - no ifs ands or buts, that's FACT.
Being a Lamborghini, the Gallardo attracts a great many owners who couldn't, quite frankly, drive nails into butter.
On comparable tyres and in the hands of the same competent driver, I expect the Gallardo and GT3 RS to post comparable lap times, with the edge in favour of the Gallardo.
I've driven the new Gallardo, the 997 GT3, 997 GT3 Cup and 997 TT. Unfortunately not on comparable tyres. I have also driven Ruf's supercharged Cayman, its a blast too. Of all these cars the least pleasant to drive was the 997 TT - a big girl's blouse.
R+C
R+C
R+C
R+C
So what do you really think about the 997?
Seriously, how do think the 997 GT3 compares with the 996 GT3?
R+C
R+C
Seriously, the G will pull the doors off of my GT3 in a straight line. It's so much faster. On like tires, the G isn't that much slower in a turn either.
Where the GT3 will kick the lambos *** is on more than one lap. I haven't tracked a G over an extended duration but due to the extra weight I have a very hard time believing the brakes would stay on it. In a GT3, just push a G hard in the braking zones and pretty soon you'll be by.
Originally Posted by Boulder GT3
Ouch, I've got a G and I can drive nails into butter as long as the butter is at room temp.
My comments are based on the current year Gallardo with the sorted suspension, different gear ratios and revised engine.
I have driven the new Gallardo, with modified brakes, for protracted periods on track, without problems. I have demonstrated to various Audi and Lamborghini engineers the problems with the stock brakes, I am a little surprised by the apparent lack of familiarity with the characteristics of good brake systems.
Most of the experienced testers here in Europe have found that the 2006 Gallardo can lap faster than the GT3, although it demands a little more from the driver at full chat.
So your butter has as many holes in it as Gruyere cheese! Great! Seriously though, I have noticed at Lamboghini driving events that the standard of driving is not as high as it is at Audi driving events. You and I both know that some of the guys driving Lambos are fairly basic, rich yes, but basic, driving skills ain't a high priority with most bottom feeders.
Recently, I picked up one of the 'Quality Assurance' Gallardos from Ingolstadt, it was brand new and I was surprised how well the stock brakes stood up, but I was testing on public roads, so I wasn't using the brakes to the nth degree.
R+C
