997 GT2/GT3 Forum 2005-2012
RMS leak advice needed...'07 gt3
Old 06-11-2024 | 02:59 PM
pcar1's Avatar
pcar1
Default RMS leak advice needed...'07 gt3
Hi guys, I'm trying to find out if this is an unusual amount of seeping for my RMS. This picture was taken 24 hours after a spirited 125mi drive.
I've researched the forums here and are all over the board, from 'never leaks', 'always leaks', to 'only when it's sat for awhile', to 'only when driven hard'. And some saying 'use the 997 turbo RMS instead of the gt3 RMS'.
On my car, I drive it at least every couple weeks (more like weekly this time of year). 45.5k miles currently; RMS was replaced prior to my ownership @ 40k (during engine-out pinning, so don't know if RMS was actually leaking at that time or simply as a preventative replacement), same shop replaced again at 43.5k under warranty. Let's assume the shop is careful during installation -- with regards to setting the seal to the proper depth and inserting perfectly square to the recess, along with using the OEM Porsche seal tool.
If, like occasional smoke on startup, this is simply a characteristic of the engine, I can live with that.
I can say this with certainty: I have now driven this car more in my 7 months of ownership than the average of each of the 8 prior owners over 17 years did. They missed out on a lot of smiles per mile.
@RAudi Driver I saw your thread from '15, though unclear what your outcome was.
TIA for any helpful feedback.
Old 06-11-2024 | 03:54 PM
Bxstr's Avatar
Bxstr
I’m wondering if the cardboard is making the leak look bigger than it actually is. For instance, if you have a drop of water on your table, it’ll be pretty small and contained. If you place that same drop on a napkin, it is going to spread out.
Mine had a small RMS leak, never a huge concern to me. Was maybe a drop or two after a couple of days of sitting.
If you replace with the Turbo rear main seal, it’ll stop the leak, but it will make a chirping sound at idle. I confirmed with Alex at Sharkwerks that this is normal and doesn’t cause any harm.
The following 2 users liked this post by Bxstr:
JpCrp (06-12-2024), pcar1 (06-11-2024)
Old 06-11-2024 | 04:42 PM
RAudi Driver's Avatar
RAudi Driver
I dont' know what this thread you speak of is. Can you post up the link?
Also, my .1 had RMS rebar by McKenna Porsche by original owner. Second owner bought it then my as the third owner. I installed an RSS center delete and once again it started leaking. I lived with it for almost 10 years as it only leaked when parked and not when the car was running, as evidenced by a clean engine. The leak was small but not super small. I'll look for a pic and try to post up if I have the time. Anyways, I then installed a full Brombacher exhaust system and the leak stopped and never returned. So the dealer's stating that the leak can be caused by the exhaust, which I always thought was hogwash, well maybe there's something to that. Who knows.
What's alarming is that this warrantied RMS repair only lasted 2,000 miles. Who did the work, are they close and, if they are legit, will they replace again for free?
pcar1 (06-13-2024)
Old 06-11-2024 | 04:50 PM
JS's Avatar
JS
Agree.
Pick up a plastic Boot Tray off Amazon and slide it under, that will give you a clearer picture.
The following 2 users liked this post by JS:
JpCrp (06-12-2024), pcar1 (06-12-2024)
Old 06-11-2024 | 04:51 PM
Bxstr's Avatar
Bxstr
My guess is this thread: https://rennlist.com/forums/997-gt2-...eak-again.html
As I'm sure most in this thread are aware, Porsche released a bulletin stating that the RMS leak is "normal" if it is not driven. Granted, I'm guessing we can all say any leak is not normal and it could have been them simply trying to get out of warranty repairs.
pcar1 (06-12-2024)
Old 06-11-2024 | 05:08 PM
flat6fan18's Avatar
flat6fan18
I've been told that the RMS will 'weep' when not driven. I noticed something similar to that when I did not drive the car for a couple weeks. Never noticed it again when I drove it consistently every weekend.
I think your car wants you to drive it more.
The following 3 users liked this post by flat6fan18:
pcar1 (06-12-2024), por944s2 (07-07-2024), Robocop305 (06-11-2024)
Old 06-11-2024 | 08:08 PM
HarmonyJim's Avatar
HarmonyJim
Totally normal. If you want it to stop completely, replace with a Turbo RMS as I did with my 2007 GT3RS. Never a drop since.
The following 3 users liked this post by HarmonyJim:
jreifler (06-12-2024), pcar1 (06-12-2024), Robocop305 (06-11-2024)
Old 06-11-2024 | 11:55 PM
JG 996T's Avatar
JG 996T
normal. never replaced rms on my 2007 RS. more drive = less weap
The following 2 users liked this post by JG 996T:
pcar1 (06-12-2024), Spyerx (06-13-2024)
Old 06-12-2024 | 12:20 AM
Ikon's Avatar
Ikon
I had the same issue a small amount of weep but after driving it a couple times a month it stopped. No more weep.
pcar1 (06-12-2024)
Old 06-12-2024 | 11:09 AM
jason95R's Avatar
jason95R
Mine will leave oil spots on the garage floor during winter storage. But once the driving season starts here in New England it stops. I wouldn't be overly concerned.
The following 2 users liked this post by jason95R:
pcar1 (06-12-2024), Robocop305 (06-12-2024)
Old 06-12-2024 | 12:04 PM
deutschmick's Avatar
deutschmick
I wouldn't worry about it. Mine had a slight weep when new; I even took it to the dealer for documentation purposes. They said it would go away; naturally I was very skeptical.
They were correct. It weeps no more!
pcar1 (06-12-2024)
Old 06-12-2024 | 12:42 PM
jreifler's Avatar
jreifler
We just did both FMS and RMS in mine. FMS had gotten quite bad, but RMS was more like yours. We used the Turbo seal.
Good excuse for RS re-gear and flywheel / clutch package.
The following 3 users liked this post by jreifler:
HarmonyJim (06-15-2024), pcar1 (06-12-2024), Robocop305 (06-12-2024)
Old 06-12-2024 | 01:05 PM
Bxstr's Avatar
Bxstr
Did you notice the chirping with the Turbo RMS too? Only at idle, once revs are applied it goes away.
Old 06-12-2024 | 01:30 PM
Auto_Werks 3.6's Avatar
Auto_Werks 3.6
Quit Smokin'
A local guy had one on his 996 GT3, and it sounded like the flubber machine when it idled. It was way more than I could tolerate. I would definitely prefer a small weep to that noise. Not sure if that's normal, or what the actual difference in the seal is.
Old 06-12-2024 | 01:36 PM
jreifler's Avatar
jreifler
It makes so much drivetrain noise now with the RS 4.0 stuff installed, but yes, I do notice the chirping. I don't mind it. So far . . .
Quick Reply: RMS leak advice needed...'07 gt3
