FS: OEM IVM 997GT3 Clubsport roll bar rear section
FOR SALE; OEM IVM Clubsport 997GT3 roll bar (997.580.986.02)
This is unquestionably the best bolt in half roll bar you can put in 996/997 chassis cars. The main hoop bolts to steel "weld or bond in" plates in the floor and the rear section bolts directly to the rear strut towers. The front plates can be either welded to the floor board or panel bonded using 3M automotive adhesive. They simply function to strengthen the floor which is very thin otherwise. The actual mounting plates with the studs which bolt to the roll bar legs are installed from underneath the vehicle with the floor board and the steel doublers "sandwiched" in between. You can see the motorsport doublers and the mounting plates in the picture below. This is the only way you can get any meaningful rollover protection and increased chassis rigidity. Any roll bar which bolts to the existing seatbelt bolt receivers is utterly useless from a safety perspective and a waste of money. These type of bars are nothing more than harness bars made to look like a roll bar. This 997 GT3 Clubsport bar also incorporates the later FIA mandate of the shoulder harnesses attaching to the rear section of the bar thereby increasing the length of the shoulder straps thus giving more "give" in a frontal impact reducing stress on the upper torso/neck. All the 997 and later Motorsport bars conform to this.
The bar below is finished in matte black and in perfect condition. It is probably the lightest legitimate roll bar out there weighing only 39.4 lbs. All installation hardware is included. If you want to maintain your car's originality using only OEM parts to preserve or enhance future value, these bars are the way to go. These are NLA.
$5500 plus shipping. Payment via bank wire or Paypal to established Rennlisters.
Can you link/source the FIA recommendation about longer shoulder straps? All I've know is the Schroth Racing suggestions for no more then 8 inches to the bar. which is opposite the FIA recommendation you are citing. See: https://www.schrothracing.com/post/s...tion-checklist When I look on the FIA recommendations here: https://www.fia.com/sites/default/fi...tion_specs.pdf it doesn't specify a length requirement/recommendation. Maybe I am looking at the incorrect document.
