997 GT2/GT3 Forum 2005-2012
Floating Disc and Pad Recommendations
Old 10-28-2023, 10:02 AM
997_rich
997_rich's Avatar
Default Floating Disc and Pad Recommendations
I've been running Girodisc floating rotors and Pagid Yellows on my car for a few years. I do some street driving and about 6-8 track events per year. This has worked pretty well for me for while. The pads do seem to have a more endurance racing feel though.
It's time to replace the rotors/pads and I'm wondering if there are other options
I was thinking about girodisc again
https://flat6motorsports.com/product...39559037943892
but also rennline.. are these at the level of Girodisc and Brembo?
https://www.pelicanparts.com/More_In...S-107-FFS&fc=Y
Also, what pads are suitable for track use? Are people using Ferodo? Which Ferodo pad are you using? Are there other options people can recommend?
Thanks!
Old 10-28-2023, 11:12 AM
MKIVdan
MKIVdan's Avatar
My 991.1 RS had Girodisc floating rotor and Ferodo DS1.11 and they ran great on the track. ZERO fade and extreme stopping power, I did 5 track days on them in one year and put 11K miles on the car and it still had a ton of pad/rotor life left.
Old 10-28-2023, 06:13 PM
radr
radr's Avatar
You should ask them where they're made. Rennline seems like it's been bought by ECS/Pelican, and ECS has their own line of private label BMW 2-piece rotors made in youknowwhere. You can just put new rings on your existing GiroDisc hats. I'd hit Clark @ Apex up for the rings.
Thanks!
I run GiroDisc GP40 pads which have worked well. Outside of that, I've liked Ferodo DS1.11, PFC.
Old 10-29-2023, 10:59 AM
craina
craina's Avatar
If the girodisc are working for you then I would stick with those. As noted above just replace the rings, pretty easy job. I like performance friction pads specifically the pfc08 compound.
Old 10-31-2023, 02:52 AM
Belinko
Belinko's Avatar
Brembo type III and pagids for the same use case. It's all personal preference. Girodisc is probably best value for performance. Just replace your rings, hardware and pads as needed.
Old 11-02-2023, 04:46 PM
francisluu
francisluu's Avatar
Ring replacement is pretty therapeutic I have to say. I also run the GP40 pads on my 997.2 GT3 and the bite and stopping power's great. On my 4.2L 981 Cayman I run the same GT3 rotor setup up front with DS1.11. A pad with less bite helps with the non-GT cars' ABS system.
Old 11-03-2023, 06:46 AM
ZMC-ZH
ZMC-ZH's Avatar
I am in the same boat, also considering the PFC V3.
Anyone using them here and any opinion?
2 things that stand out, the extra cash demanded versus other options and the bigger (373mm) rear disks with spacer needed.
https://www.driftshop.com/pfc-v3-rea...e-997-gt3.html
Old 11-03-2023, 08:32 AM
911rox
911rox's Avatar
Have been using PFC rotors for the past 10 years. My most recent set up was the PFC v3 fronts with RE10 brake pads all round. Stayed with OEM rotors on the rear since they are less prone to cracking. The PFC rotors are faultless- no vibration, hard wearing and long lasting. Probably got 3-4 times the life of the OEM fronts. Rock solid option!
Old 11-07-2023, 12:45 PM
ZMC-ZH
ZMC-ZH's Avatar
Thanks.
I have PFC v2 on my M coupe and liked them. The pads (08) did detach from the plate which for such $$$ pad is not acceptable.
I got them switched with Z rated and since then it is Ok. The car doesn’t see track time now.
Also pondering to take the jump to ceramic, ST or similar.
Quick Reply: Floating Disc and Pad Recommendations
