Front lift
Hunker down and read this thread. Likely your 13 bar switch has gone bad.
https://rennlist.com/forums/997-gt2-...-cpo-pcna.html
There is an entire thread on this.
https://rennlist.com/forums/997-gt2-...ispreloading=1
Skip to the end. Bottom like is you need to replace the 13 bar switch. It’s an easy job and the part can be sourced from Porsche for about $400 or directly from Suco for about $50 each if you buy 10 or more. If you have a 2010 model year, pull out the switch first to verify the thread size you have. Suco no longer sells the 1/8 BSPP size so you would have to get it from Porsche.
