Removing Old PPF from gt3??
@RapidGT
Paint is original but so is the PPF -- been on there since 2010ish from what I understand. It's starting to yellow so I'd like to have a professional remove it and ppf the entire car but I was advised that there is a chance some of the paint could lift off on removal.
It looks brand new. I think if I were to do it over again, I would just have the professional take it off with a proper heat gun, but my car looks brand new, just go slow or have someone you trust do it and you will be fine.
I've done this a few more times than I care to recall. Bottom line - with adequate care, patience, and beer, any PPF will come off without harming your paint.
I just finished a job on my RS America, which may have had the first PPF ever installed on a vehicle. It was terrible. But it's off, and no harm was done.
If you have the means, take it to a professional. If you're a sadist, get a heat gun, steamer, and as much of this product as you can get:
That stuff will literally melt the PPF away. But it's still a huge PITA. You can combine with one of these: https://www.autogeek.net/bf-bug-sponge.html That'll go a long way against the residue, and for really stubborn bits, don't be scared to use a plastic razor blade. CAVEAT - You MUST then paint correct, b/c the razor blade will impart superficial scratches, but you'll need a full paint correction after PPF removal anyway.
Premium Sponsor
If removed properly, use steam and nice/slow pull, there shouldn't be an issue
Residue can be removed with a solvent like CarPro TarX
If paint does lift, rare on OEM paint on metal, but possible on plastic areas, document the damage, and have a very reputable shop that specializes in Porsche do the repair
It's catch 22...if you don't remove it, the uncertainty will be a concern for you and future owner...if you do remove it, possible lifting, but at least you'll know for sure
IMHO, I'd remove it and hope for the best
Specializing in Porsche/Ferrari since 1995
Why choose GP...WATCH OUR DOCUMENTARY
Follow Moe HERE
GP Fastrak - Ceramic/PPF/Tint in one simple bundle - Click Here for more info
Follow Moe HERE
Yea my ppf guy said most older Porsches are fine except the plastic bumpers And some headlights.
Any large PPF removal will require a paint correction imo because it’s almost guaranteed going to get surface scratches removing excess adhesive.
I did my roof as a test but I’m procrastinating because a $7k ppf + $1500 correction +$500 removal + $600 graphics sounds annoying
only common advice the videos have around both adhesive and avoiding paint removal is DONT peal ppf back, pull it up and toward the lose end
my ppf is over the RS graphcis. there is a slight outline evident.
no issues removing 8 year old original film (buff & beyond not me)
