Battery
@Antigravity dropping the knowledge as always!
I've noticed that when modern Porsches (even 997 generation) get weak batteries, that they will throw A LOT of error codes. I have caused this condition accidentally in the past and it takes quite a bit of time and effort with a modern OBD2 scan tool to right all the wrongs. One thing I learned the REALLY hard way is that if you leave a Porsche key in the ignition that it is game over for the battery over a period of days. I actually ruined a 1.5 year old lead-acid battery by doing that, and had to buy a new battery to resolve the problem. Ah, the life of a car dealer...it's rarely glamorous!
Just popped the 60ah AG in my .1 RS. I typically drive it every week at least once but depending on travel, weather etc. its possible that it sits for a few weeks at times. Noticed by old battery was weak after a couple weeks of sitting but no such issues with the AG. I am also keeping on the maintainer on it when I know it will sit for more than a week anyway but nice to know if you forget, you’re covered.
The following 2 users liked this post by Maverick11:
996TS (04-29-2023),
Antigravity (04-21-2023)
Premium Sponsor
last question for you: I have the ctek special charger for my scud, but can I use a noco genious (with the lithium battery mode option) for my new battery, or do you recommend sticking with the c-tek charger that you guys recommend? I already have the noco but will buy the ctek if you guys state the noco is not ideal for these batteries.
Its the 1 amp maintainer type of maintainers that really don't want to use since they won't put a good charge on a battery in a Car. As an FYI... the higher the Amps the Charger is rated for the faster the recharge will be, but being realistic not everyone need a super fast recharge so the 4 Amp CTEKS and others are fine. I have a 25Amp CTEK commercial charger since we have to test and recharge over and over and it chargers super fast, but is silly expensive and not really needed for anything other than a shop.
Premium Sponsor
The following 2 users liked this post by Antigravity:
996TS (04-29-2023),
Steve Theodore (04-21-2023)
Yes for sure you can use the NOCO...or most any specific quality brand of Lifepo4 Charger. The main issue is to make sure it has at least a 4 amp charge rate since even when chargers, such as a CTEK, OPTIMATE or NOCO are rated at 4 amps, that is only the peak rate of charge. They are usually only charging at 2 amps for most of the charge cycle, and that still takes a pretty long time to recharge a fully discharged battery like a Lead or Lithium Battery. But it fine for maintainance and to get a charge back into a battery.
Antigravity (04-23-2023)
This post just saved me! Thanks madmurdock
Unfortunately it seems Voltphreaks is not in business anymore?
I got mine for my 964 in 2015, so the thing is near 10 years old now and still works fine used in my 964, not sure how much total capacity is left at this point.... I keep it on a CTEK tender.
Maybe another maker has a similar battery size to the v6, that has over/under charge protection, shut off circuit, DIN sized terminals, Lithium Iron chemistry, etc.
If you have low voltage, regardless of battery brand or type, you could end up with a bizarre situation like I did last month. I have used the larger H8 AGM for quite a few years, and even a new/year old battery can fail-and when it does and you're in a bad area, or late at night, getting a flatbed for a GT3 still requires ramps-luckily I was able to avoid that and I detailed this experience for those who might have an issue. And after using PIWIS to clear all sorts of codes once I put in the new replacement battery, from what I saw, the TC+SC only gets reset after a drive around the block, even after doing a VAL and Vehicle Handover with PIWIS after clearing out all codes.
And my battery is on a CTEK constantly since the car is not a daily driver:
I'm glad this didn't happen at a gas station or a worse scenario:
https://rennlist.com/forums/997-gt2-...stuck-key.html
JB
JB
