Existential LWFW Question
Was chatting with my buddy about his new to him 7.1, and I made a tongue-in-cheek comment about him needing to get accustomed to it sounding like it was chewing marbles at idle and on clutch disengagement.
He disavowed any such impressions, and that got me thinking - Does my 7.2 non-RS have a LWFW ?
My inherited records for this car were not thorough when I bought it. It certainly had a good bit of preventative and regular maintenance done, but no performance mods, and so it never occurred to me until now that a PO might have swapped in a LWFW.
I've had other P cars with LWFWs, and this car sure ticks all the boxes (lots of chatter at idle and clutch engage / disengage, super quick revs, wants to stall easier, etc.). So, is there a definitive way to tell if it has a LWFW without dropping the trans ? I'll be installing a Guard diff later this season, so might take that opportunity to do the clutch as well, but in the meantime, my curiosity is piqued.
What say you?
What say you?
Edit: as pointed out below, .1 GT3 you can tell based on crank pulley. For .2, both standard and RS car use the same crank pulley so you cannot tell.
First and easy thing I’d check is which crank pulley you have. You can easily check this by looking underneath the car.
http://www.evomsit.com/EPK_GT2_CS.htm
It shows 996 in the pics, but if you have a solid looking crank pulley that is an indicator you have a LWFW.
Robocop305 (03-17-2023)
That is the crank pulley for a LWFW car. Highly unlikely it would have been swapped if your car didn't have a LWFW. So I'd put my bets that your car does have a LWFW.
Let others chime in to confirm I'm correct, but if I was looking at your car with that pulley, I'd certainly say it has LWFW.
The aesthetic difference between the two, as shown in the link I posted earlier is that the LWFW one doesn't have all of the holes, whereas the DMFW one does have all of those holes on it.
I can't say what the actual mechanical difference is though. I'm guessing weight? Also a different bolt and washer. There's some more details here too.
https://rennlist.com/forums/997-gt2-...n-gt3-s-3.html
basically just showing the LWFW creates enough momentum fast enough to hit lvl 2 DME if revving from idle
Interesting development. I'm planning to inspect cam bolts in a few weeks when I re-do my exhaust setup. Guess I'll just budget that annually from now on.
Not sure I have, but I've always thought there was no mechanical way my car could possibly rev any faster . . . And I have seen the Sharkwerks videos and other RS rev vids. Seems the same.
Thread with videos. https://rennlist.com/forums/997-gt2-...l-testing.html
I’ve wondered the same about my heavily tracked 7.2 non-RS…here’s my pic. Curious what the OEM pulley is supposed to look like; tried searching online but I’m probably not using the right terms.
I’ve also experienced similar characteristics as OP described, but chalked up the “wants to stall easier” to my lack of experience driving her! Lol
Robocop305 (03-18-2023)
are you sure about this? My 7.2 is 100% stock and it has the same pulley shown in OPs pic. Zero clutch chatter, which is actually one of the reasons I went with a base over the RS.
Received 2,448 Likes
https://www.sharkwerks.com/2010-997-...kwerks-exhaust
fayraree (03-18-2023)
This is the stock pulley that Sharkwerks showed in their journal of this 2010 GT3.
