997 gt3 driver seat noise
Wow, that's a hard one. I think a seat pull is in order. Did you check to see if the seat was rubbing against the center console? Doesn't sound like metal. Sounds more like leather and carbon making the noise.
Is it any plastic in the sliding mechanism for the seat? Since the sound also occur only when pushing the lever(without moving the seat)
Definitely a tough one, Magnus. Since your seats are covered in perlon, I doubt they are rubbing and causing any friction noises. I would pull the seat from the car to see if it can be replicated. It's a really simple job and only requires an E12 torx socket. Just make sure to disconnect the battery before you do to prevent triggering airbag lights etc.
You may be on to something with the slider or adjustment lever being the culprit and perhaps they could use some grease.
You just may need a new slider. Maybe yours got bent or lost a bearing or two or something.
The following 2 users liked this post by norwegen911:
Clifton (03-23-2023),
RAudi Driver (03-22-2023)
