997.2 No Aux Input?
I just purchased a .2 RS and it seems that the center console was swapped to a painted unit. This unit has a switch right near the hand brake, of which I have no idea what it does (?) and only has a 12v source in the armrest. Could this be a .1 console? Do all .2 have aux inputs in the console? Looking to connect my phone audio. Thanks in advance.
You may want to post a picture, but both PCM 3 and CDR30 had aux input. PCM also had a spot for USB. So yes, there should be an aux plug there. Also on both .1 and .2 console there should be a 12v in both armrest and in console itself under flip up lid.
Received 2,397 Likes
Does your car have the Universal Audio Interface option? If it doesn’t then the car won’t have an AUX port. You get an AUX port as well as iPod and USB ports with the PCM 3.0 in conjunction with the Universal Audio Interface. Universal Audio Interface with the CDR 30 gets just an AUX port. I believe this stuff can be retrofitted.
If you find that you don't have an aux, I have a nice cheap Dension Gateway 500 in the classifieds that will solve the problem
Good luck!
Good luck!
Yes I use the radio! This car's sound system is pretty good and when you live in LA, chances are you're gonna be sitting in traffic on either end of any fun drive.
