Recently installed Dundon Power Package 997.2 GT3 - Feedback inside
The tune plus pipes will allow for some gains but the real power is balancing the intake side of engine as well. Idk if you’ve seen Dundon’s video explaining some of the science behind it but after viewing it, it was worth the try for me.
Oh and the sound, it’s sounds so good!!! Hope this helps!
Excellence. No fear on the Foggy track…. Wow!
have dundon 4.0 carbon airbox ready for installl…. 8 degrees now, will wait a bit.
Great stuff! Thank you for sharing. I have to admit, this thread has sparked my interest. One thing I haven't been able to find is a good picture of how the mini-crack tips fit relative to the bumper. I realize this stuff is about function, but I do care about form as well. Would you mind sharing a picture of the exhaust tips with the bumper in place? Thanks and please enjoy that beast often!
Did you do a pre and post install dyno run under the same atmospheric conditions on the same exact dyno? That would be great data...
sounds incredible
Unfortunately I do not, I had Spec German do the whole install and we installed an rs4.0 clutch/flywheel at the same time so it required a few hundred miles for break in before I could go full send. Dundon is a good 60 minutes away from me and haven’t had a chance to make it down to put it on their dyno yet.
Elliotw44 (02-14-2022)
How much louder is the header/mini crack pipe combo valves closed vs stock, valves open? I have a Sharkwerks center bypass but thinking of adding the street headers to it.
