Antigravity battery fault - can anyone advise ?
Folks, some help from those of you with experience of the AG batteries.
The error message in the pic below popped up today for the first time ever, my alternator is quite new so thinking it must be something to do with the battery, the model I have is
Antigravity H6/Group-48 Car Battery 60AH
The Unit is 10 months old, it hasn't been on the charger for a while but has been in regular use.
Any ideas what to do, I stuck it back on the charger and will plug into into Durametric later to see if there's a code, but has anyone else experienced this ?
![](https://i.ibb.co/BZ0XQLw/Battery.png)
andean ruminant 5 letters
Fault code was P1699 Communication with generator interrupted
I've erased fault code and it hasn't come straight back yet any thoughts ?
Thks
Thks
Premium Sponsor
Did you reach out to us yet TB? I'm not at the office but just wondering. If the battery is low on energy or hasn't been charged in a while and not driven enough to keep it charged then that could be a low voltage error potentially. But you also said you Alternator was newer... so is it newer than the battery? The battery will work the same as always if its in a regular state of charge. Please note that the battery is just a storage vessel for energy, it does not PUSH energy into any part of the car, in fact energy is only pulled from it when a circuit is completed such as turning on a light switch. It is the same with the starter motor... the pull the energy from the battery. So be assured the battery isn't hurting anything.
My other question would be is the battery sitting at 13.2v and have you put a good charge on it? It it is and the car is starting well it should be all good.... Porsches can be a bit finicky with voltage but also is something interupts the signal it can throw a fault but won't have anything to do with the battery also. So check the voltage of the battery first.... see if the flag comes back since you cleared it.... it might have been a low battery or simply the alternator doing something under load.
Premium Sponsor
Great, let us know if anything comes up and we can have you test some other stuff, but being honest we don't see this often. Yes there are occasional flags when any battery gets low in a Porsche, but it usually not a battery fault for the most part, UNLESS the battery in fact is going bad and is not holding its voltage. But your Lithium Battery will last for many many years without going Bad so to speak. This is because it has built in protections to prevent it from what normally damages a lead/acid battery such as accidental over discharge into the below 9v ranges.... our battery won't allow that to happen since it has a Battery Management system inside. So if the battery is sitting at 13.2v and starting the car easy then in most circumstances all is well, but in any case always feel free to reach out to us with any questions. We know this is a new Technology and people will have questions.
Steve Theodore (10-29-2021)
Following a full charge the error warning has stayed off, I bought a cigarette lighter voltmeter so I can monitor for anything suspicious.
Car has been on the charger/maintainer for 4 days I took it to work this morning it showed 13.3 volts when I disconnected the charger started vigorously, about 2 miles down the road the same error light flashed up again I switched off the engine and back on again the warning came back on but then went off on its own and remained off for the duration of my 30 mile commute. I noticed it was reading around 14.2 volts for most of the trip.
I will check see if there is a stored code when I get home today.
