Solid Links and Creaking
Hi fayraree:
Get some new bolts and check the roll bar link bolts for stretch. Folks often really torque them and this causes visible deformation on the bolts.
As a FYI: If you can easily more a rod end in your hand, you either have freakishly powerful hands or a bad rod end - and I'm betting it's a bad rod end. You should not be able to move them around. These wear out, and most that are found on the aftermarket are not that good...
Ray
Ray
fayraree (03-13-2023)
