Noise, rattle udder defroser
So,,, i have a noise coming under defroster.
When I stick my fingers in the gap, I feel a loose rubber-like object that extends to both the left and right side. Does anyone know how I can most easily fix this, or what part I feel?
![](https://cimg3.ibsrv.net/gimg/rennlist.com-vbulletin/2000x1504/defroster_noisejpg_953a62d1a225e84419315a7a036d7636810590fb.jpg)
Hi, you need to be a lot more detailed in your request.
The noise happens when the defroster is on or all the time?
The noise is coming from the left or right side?
The noise sounds like......?
Looks like you have a broken piece that came off your dash, defroster area. Could that be bouncing around and causing the noise?
I dont have another car nearby to compare with, maybe someone have loosen the defroser and perhaps have an image?
