FS: Stoptech STR World Challenge 380/355 mm brakes
Details at: https://rennlist.com/forums/market/1264907
Selling a complete, four corner set of Stoptech STR World Challenge 380/355 mm brakes purchased new in 2015. This kit will fit a 997.1 Cup/997.1GT3RS with PCCB/997.2GT3RS GT3/997 Cup. All four rotor rings are mounted with StopTech MAX-float hardware which allow 0.4mm of axial rotor float.
Note, because the rotors have floating hardware they will make a “clunking” noise at slow speed.
This kit will also fit a 996 GT2/GT3/Cup/997.1 GT3 no PCCB with a set of brackets with 143mm bolt spacing from StopTech.
Passenger rear caliper has some cosmetic scrapes but it does not affect the caliper. See photos.
I’ll take measurements and photos of the rotor rings and pads shortly. Prefer a local pickup in the SF Bay area, though I sometimes make trips to SoCal.
Includes the following USED parts::
- 83.796.6800.R1, STOPTECH TROPHY SPORT BIG BRAKE KIT - FRONT- 380X32MM ROTOR ST-60 6 PISTON CALIPER - SLOTTED
- 83.792.0047.R1, STOPTECH TROPHY SPORT BIG BRAKE KIT - REAR - 355X32MM ROTOR ST-40 4 PISTON CALIPER - SLOTTED
- 89.000.0022 StopTech Pin Kit, Race
- StopTech front caliper adapters and hardware
Includes the following NEW parts:
- StopTech front and rear staineless steel brake lines
- StopTech rear caliper mounting hardware
Kit does NOT include:
- brake fluid
- brake fluid
