997 GT2/GT3 Forum 2005-2012
Smog Check and EVoms Tune
Old 07-15-2021, 02:50 AM
Sword_of_the_Spirit
Sword_of_the_Spirit's Avatar
Originally Posted by FLT6SPD
Still have it new in box, last one pcna had for 997.2 turbo. It has to be fully programmed down to the key/vin/base file from the homeland, not sure if a third party can do it.
Got it. Sounds like it would have to a special clearance case from Porsche Int. to allow it (I'd assume such if one needed it really, really badly). Maybe they figured you had a good one already...
I didn't know you got rid of the other .2rs. Must have been tough to let go or it went to a very good friend in case you wanted it back. Figured one for you and one for the Mrs...
Old 07-15-2021, 03:21 AM
D-Uber Cars
D-Uber Cars's Avatar
Passed, in WA state. Simple OBDII plug in check, no tail pipe sniffing. As long as you are not throwing a code, should pass. EVoms Tune, w/full Dundon catless exhaust.
The following 2 users liked this post by D-Uber Cars:
Elliotw44 (07-21-2021), Steve Theodore (08-20-2022)
Old 07-16-2021, 08:31 PM
ChrisF
ChrisF's Avatar
Originally Posted by Sword_of_the_Spirit
Got it. So no E85. Maybe I confused you with another. Got to hand it to Mitsu. They made some good ones. Miss mine as well as posted a bit on EvoM under the same handle.
Enjoy your boosted household!
Mine is E85 too (dual map). In the old days, we used to use the E85 tune to pass even without cats. When they switched over to the OBDII plug in tests, you have to get the ECU as stock "looking" as possible to their computers. This go round, if it doesn't pass as is, will have to swap back stock injectors and full original ECU file.
E85 in these cars is stupid fun.
Old 07-20-2021, 11:55 AM
Spyerx
Spyerx's Avatar
Received 1,793 Likes on 1,091 Posts
The inspection starts yesterday as indicated below, using the ECU Checksums. Up until this point if all your smog indicators were active and set cleared, and, no CEL, you'd pass.
Now, they are comparing the ECU checksum with known database of values. So, firmware released with car = ABC. The checksum creates a value of 123. The DMV computer looks at a database of the VIN, and expects to see a value of "123". I can only assume this creates an interesting burden on the auto makers to supply these values, probably related to their smog certifications...
"MY" (and this could be wrong) understanding of this is that this operates similar to say, an MD5 checksum. That is, it's calculated by the ECU. So if the firmware file itself is modified in any way, the checksum will not be the same. Now, given firmware can be hacked, it would be interesting to know if the checksum they will look at if that field is even editable, or, if it's calculated at startup by the ECU. Should be interesting. But, its software, and where there is a will there is a way.
I know a couple ECU tuners (meaning, they hack the software/hardware, not just program values) I'll reach out and ask them their thoughts on this...
Old 07-21-2021, 12:03 PM
RAudi Driver
RAudi Driver's Avatar
Received 2,923 Likes on 1,730 Posts
Thanks Syprex. I'm safe for 2 years but time flies and I know I'll be in this predicament in no time. Glad I got in before the doors closed. I didn't even know it was happening.
Old 05-02-2022, 06:59 PM
ilko
Agent Orange
ilko's Avatar
Just passed CA smog w Evoms tune. No issues.
The following 2 users liked this post by ilko:
engerman (06-05-2022), RAudi Driver (05-02-2022)
Old 05-02-2022, 07:58 PM
RAudi Driver
*** Yea!
Nine1won (05-02-2022)
Old 05-02-2022, 08:31 PM
Nine1won
Nine1won's Avatar
Great to hear as I just ordered a tune from Sharkwerks!
Old 08-19-2022, 05:37 PM
afrancke
afrancke's Avatar
And I just failed
2004 996tt x50 evomsit tune
Old 08-19-2022, 10:37 PM
jayzbird
jayzbird's Avatar
Sucks. When BAR started this they were cagey about if/when it would be applied to which cars. Seems like the game is up for anyone without something like a Cobb that can easily flash back to stock.
Old 08-20-2022, 02:15 AM
cooler2442
cooler2442's Avatar
Received 1,492 Likes on 797 Posts
Originally Posted by afrancke
And I just failed
Do you just go and re-smog with stock software or are you getting sent to a state ref?
Old 08-21-2022, 01:12 AM
Wonderdan
Wonderdan's Avatar
Received 1,139 Likes on 612 Posts
I don’t have experience with Evoms but I have a lot of experience with passing and not passing Dundon Pro tunes.
Is your exhaust modified… if it’s just a tune does Evoms not let you flash it back and then do a drive cycle?
Old 08-21-2022, 06:07 AM
afrancke
afrancke's Avatar
I attempted to reflash and go back for another try, but that failed. Before I went, I checked for all emission tests ready using Durametric, and it was happy right away (no drive test needed) - odd. I ran a reset on fault codes; there weren't any, but I told it to reset anyway hoping to trigger the emissions monitors to unready themselves, but they didn't. When I got to the shop, the tech warned me that the EVAP monitor wasn't appearing at all. Turns out it was all of the interesting monitors (catalyst, heated catalyst, etc.) that had gone missing.
See this thread for my open questions about why this might be so.
P.S. I should note that this is a 996 tt, not a 997tt or GT car, but I saw this thread when searching around for answers to these failures and since the two are close, I thought it would be relevant to warn folks. Surely if they're checking for 996 ECU mods, they'lll be checking for 997 as well at this point.
Old 08-21-2022, 09:34 AM
Wonderdan
Wonderdan's Avatar
P.S. I should note that this is a 996 tt, not a 998tt, but I saw this thread when searching around for answers to these failures and since the two are close, I thought it would be relevant to warn folks. Surely if they're checking for 996 ECU mods, they'lll be checking for 997 as well at this point.
I don’t know what your tech is talking about with the evap disappearing… do you have access to a friends PIWIS II. Are you sure he isnt just saying evap not ready… do you have a pic of the full fail report?
Looking at your other thread I, don’t want to be oversimplify but your readout looks text book drive cycle. It says you tried to get them to ready by driving a lot. If your not intentionally trying to set them with an extremely strict drive cycle it can take thousands of miles of regular driving.. once it it took 3500 of mixed miles for everything to set for me.
If your flash messed up your computer as your tech implied your car wouldn’t even know what O2 mix to use, the other sensors would be off etc and you’d have an engine light.
RAudi Driver (08-21-2022)
Old 08-21-2022, 10:11 AM
RAudi Driver
Can you post up this shot where we can see the entire page?
Quick Reply: Smog Check and EVoms Tune
