Where is the throttle position sensor on the 997.1 GT3
Good luck.
If you have both signals on your durametric, can you see a higher value in sport mode.
Select Sport mode and I would expect a faster ramp up of throttle body signal relative to pedal position.
A glitch could easily have happened during a power loss cycle, where the correct voltage in the sensor system is lagging during a power up reset, or whatever.
