997.2 LED tail lights help
Looking for some help on a LED taillamp part. I purchased a set of clear LED's from a member here for my 2011 7.2 RS. Problem is the connector is different and therefore doesn't fit on my car. The lamps came as promised, still in the new packaging and never installed, so I have no gripe with the seller as he was not aware they didn't fit.
The part number for the correct lamps is
The part number of the lamps I received are
Anyone know which model these "as-tail-lamps' fit? And why the hell does Porsche make different connectors for the same stupid lamp?!?!? Grrrrrr........Thanks in advance.
Thanks for any help.
997-044-900-07
https://www.sunsetporscheparts.com/oem-parts/porsche-rear-light-clear-set-99704490007The part number of the lamps I received are
997-631-993-03
https://www.sunsetporscheparts.com/oem-parts/porsche-as-tail-lamp-99763199303Anyone know which model these "as-tail-lamps' fit? And why the hell does Porsche make different connectors for the same stupid lamp?!?!? Grrrrrr........Thanks in advance.
I'm not sure if this is the issue since you already have a 997.2, but when upgrading from 997.1 to 997.2 there is a slight modification to the connector that is required (see picture below). Maybe your situation is totally different.
BTW, another member likely found the answer to why they are different. I probably have Euro spec lights. Connectors are apparently different but the internals are the same. Blinkers will flash yellow instead of red, but that doesn’t bother me. Still don’t know why Porsche decided to make the tabs different, though??
Problems solved.
I got it figured out thanks to the link member nwGTS on the 997 forum provided. I removed the backing piece from the lights (seven T20 torx screws for each light), disconnected what I'm guessing is the reverse light (2 more T20's), a few wires attached to the circuit board via a clip, and the all-important pin-connector (one T20 screw). Swapped them out between lights, and VOILA! It works. The only difference is the indicators are amber instead of red. Don't anticipate running into any issues with that unless some PO notices it and gives me a hard time. Now I have a set of red lights (with the Euro connectors that a swapped out from the clears) for sale if anyone is interested.
Problem solved. Red LED lights for sale (with the Euro connectors)
https://rennlist.com/forums/market/1134508
Just an FYI...
For those who want the 997.2 LED Euro Tail Lights for the amber turn signals and wants to do it the right way you can use the following connector 6Q0-973-713-A 6 Way Sealed Female Connector 1.5 mm, 2-row, Coding II
Works on both Left and Right Tail Lights.
- FUNGC
- FUNGC
Elliotw44 (11-12-2023)
