DSC Sport calibration files
For you DSC users out there - what calibration file are you using on track with OEM shocks?
DSC have 3 for download:
OEM/Bilstein
Slightly firmer
Substantially firmer
Using for the first time and want to avoid wasting time at the track playing with maps/config if I can.
Matty
OEM/Bilstein
Slightly firmer
Matty
OEM/Bilstein
Slightly firmer
Matty
OEM/Bilstein
Slightly firmer
Matty
If you purchased your DSC new in 2017 or later, it has the middle map(slight firmer) in it already, which is the most popular by user preference. The original map has min value that was too soft by preference of most users. Again, the max values are the same for all three maps.
Hope this helps.
PS- I know that's a lot of info so its okay to think less about it and enjoy.
Thanks for this Tom. So I am clear you are saying:
The “sport” mode on all 3 maps is identical and only the “normal” mode differs?
if that is the case then it would seem the “substantially firmer” map would allow “normal” and “sport” modes to be used on track (given “normal mode” is also very firm).
And the “OEM/Bilstein” and “slightly firmer” maps would perhaps be more of a “normal” = street driving and “sport” = track driving.
Matty
Matty
The Shock Calibration of the 3 maps are all the same.
Only the low end of the range and sensitivity is different.
Another words when the car exceeds 0.5g all 3 maps perform the same.
It only at lower g-force that they feel different.
Tom - I found two differences in the sport mode between the “slightly firmer” and “substantially firmer” maps.
1. Travel stops: this is populated in the “slightly firmer” and empty in the “substantially firmer”. Is this feature used?
2. G comfort default: 15 for “slightly firmer” and 20 in “substantially firmer”. Given these maps are meant to only differ in normal mode, is there little to no real difference in between 15 and 20?
To have a better understanding of these function you should read the DSC Software User Manual from the DSC Sport website. There's also additional resources in the DSC Tuner Software at the top of each page "Help" > "Open Help Dialog" , and I think I have answered same questions a few dozen time on this forum alone.
As a side note, these are DSC supplied 997 calibration files: removing settings that dont do anything on this platform would also stop ppl asking about them
