997 GT2/GT3 Forum 2005-2012
Brake and clutch bleed today >>
Old 03-06-2018, 05:43 PM
  #31
Hoyt
Hoyt's Avatar
I modified my Motive Bleeder this past weekend by adding an extra quick connect fitting I had from my air compressor. Overall a much easier process now with the quick disconnect. It made flushing the brakes on my E30 M3 mush easier. I also tried it without fluid in the Motive bleeder and it was actually not as much of a hassle as I thought by adding fluid to the master cylinder reservoir every so often.
Old 01-26-2021, 04:54 PM
  #32
purcell21
purcell21's Avatar
This is the best news ever to learn that I don't really need to bleed the clutch slave like I did in my 987.2. I've got the GT3 up on the lift with all the access I could want and STILL can't see a hint of the clutch bleeder. Even if I could see it, I don't see a way to get my hand up there to get a wrench on it without removing stuff. So, what did you remove to do it? Maybe share a picture with us.
Quick Reply: Brake and clutch bleed today >>
