2010 Black Porsche 997.2 GT3 BBi 4 Liter StreetCup Build
Basic Sponsor
We joined forced with our friend Jeff to build this 2010 Porsche 997.2 GT3 to be the ultimate balance between a street car and track monster. This beast comes complete with our freshly built 4 liter engine, full suspension package, roll bar, aero upgrades, Forgeline Wheels, and much more.
For more power, we decided to go with our stump puller of a 4.0 liter because we wanted the midrange punch. This gives us the ability to power out of a corner without having to be so high in the RPM range (engine still rips to 8800 rpms) but still have the power to have a lot of fun. Our BBI StreetCup side muffler bypass pipes helps keep that added torque in the midrange up and maximizes weight reduction. As part of the rebuilt process, the bearings, gaskets, chains, cam followers and actuators were all replaced; the oil pumps were thoroughly inspected and the fuel injectors were cleaned, balanced and calibrated
For improved improved handling, we installed our full suspension package with adjustable arms and a set of Ohlins Road and Track coilovers. The dampers utilizes the Hydro-Dynamic Damping technology that Ohlins has implemented in the Road and Track line to deliver daily driving comfort with track driving performance. We increased the spring rate in the front to compensate for the added mechanical grip that we got from the wider front track and wheel/tire set up. To have a naturally balanced setup, we also went with the wider rear wheel and tires.
To sum it up, the engine delivers great power from 4000 rpms to 8800 rpms and the chassis is very predictable and natural. As a result, this car is must drive and we are confident that the new owner will be very happy with the driving experience that it delivers.
Car:
Upgrade List:
Engine
•New BBI 4.0L with 105.4mm Piston and Cylinder Kit
•Rotating Assembly Balanced to 2/10th of a gram.
•Engine Rebuilt with All New Bearings, Gaskets, Chains, DLC Coated Cam Followers and Cam Actuators.
•Welded Coolant Lines
•BBi Cam Actuator Repair
•Cobb AP with Custom BBI Calibration Fully Dyno Tuned to 91 & 100 oct.
•50 State Legal BBI StreetCup Side Exhaust with OEM Titanium RS Muffler
•Light weight flywheel and 4.0L clutch set up (fully balanced)
Exterior
•GT3 Cup Fender Flares and Inner Liners
•Custom Carbon Fiber Decklid RS style
•OEM GT3 RS Rear Wing and Risers
Suspension
•Full BBI StreetCup Control Arm Package (all of the goods)
•Ohlins Road and Track with BBI spring package
•Aggressive street/Track Alignment & Corner Balancing
Wheels & Tires
•Forgeline GA1R CL 10x19 Front & 12x19 Rear Wheels
•Michelin PSC2 265 front and 325 rear
Interior
•BBi StreetCup Roll Bar Gloss Silver
•BBi StreetCup Seat Base & Slider Kits
•RECARO Pole Positions Racing Seats
Bringing Passion, Artistry, Craft to the Porsche Tuning Industry
Southern California's Porsche Performance Tuning, Engine Development,
ECU Software Tuning, Custom Fabrication, Race Preparation & Factory Service Center
Website: www.bbiautosport.com Email: sales@bbiautosport.com Phone: (714) 843-0200
Follow Us On: Facebook & Instagram
Basic Sponsor
Interior
BBi Autosport StreetCup Porsche 997/996 Roll Bar
Features
Product Link:https://www.bbiautosport.com/product...etcup-roll-bar
BBi Seat Base & Slider Kit Porsche 996/997/991/987/981 Seat
The BBi Autosport race spec seat mounts are a direct bolt in to the factory mount location for a hassle free, easy installation for your competition race seat. The BBi Autosport Seat mounts have a large range of adjustment options allowing fitment for all major FIA and SFI approved seat brands and offers an integrated 5 and 6 point sub belt mounting location.The wide range of adjustment covers almost all possible seating preferences to properly seat drivers of all sizes. CAD designed, CNC laser cut and formed from one piece of .125” (1/8”) carbon steel with no welds to maximize strength and stiffness. All mounts are powdercoated with a wrinkle black base and satin black sides.
Features
Product Link:https://www.bbiautosport.com/product...and-slider-kit
Recaro Pole Position Racing Seats
The RECARO Pole Position racing seat provides ergonomic S shaped shell forms to the back and "built-in" lumbar support to protect against spinal compression in high impact accidents. Combined with high quality foam the seat is outstandingly comfortable. The bolsters and deep seat cushion pocket cradle your body. The seat holds you firmly in place preventing the fatigue and discomfort caused by unwanted movement during aggressive driving maneuvers.
Features
Features
- 1.625" x 0.095" 4130 chrome moly steel tubing utilized for excellent strength to weight ratio
- Made from 4130 chrome moly steel tubing (1.5" x .120" main hoop & 1.5" x 0.95" rear hoops) for excellent strength to weight ratio
- TIG welded and utilizes "X" braces on both front and rear sections for superior strength and rigidity
- Mounts to front seatbelt mounts and rear strut towers
- Utilizes laser cut mounting plates & inner diameter tube clamps that are CNC turned and milled for a precise and seamless fit
- Designed to work with stock or any aftermarket seats on the market
- Can be used with stock seatbelts or 6 point harnesses for track use
- Designed to work with wrap-around style harnesses while optional eyelet bolt provisions are available for clip-in harnesses
- OEM fit & finish. The main hoop contours entire arch of the roof with an even 3/16 inch gap
- Finished in satin black powder coat. Other optional colors available
- Designed to fit all models of the 996 and 997 chassis including the Carrera, Turbo, GT2, and GT3
- Compatible with factory Bose subwoofer
- Bolt-in installation requires no drilling and minimal carpet trimming
- Made in USA
Features
- Precision CNC laser cut and bent from one piece of 1/8” 3mm carbon steel (base & side mounts)
- Multi way adjustability
- High strength sliders, mounts to base with 4 bolts per slider
- Integrated 5 and 6 point sub belt mounting locations
- Stylish design with laser cut BBi logo and durable satin black Powdercoat finish
- No modifications to vehicle or any seat mount components are required for installation
- Uniquely designed for Porsche vehicles for the best possible fitment
- Mounts to factory bolt locations with precise factory fitment
- Fits all major FIA/SFI approved seats up to 17”
- 14-3/4”¬(375mm) to 17-1/2”(445mm) width adjustments (standard side mounts)
- 16”¬(375mm) to 18-3/4”(445mm) width adjustments (optional wide side mounts)
Features
- FIA Certified and Crash Tested
- RECARO Proprietary Ergonomics
- Aggressive Thigh & Torso Bolstering
- Lumbar Cushions
- Screw Mounted Panels and Belt Slots
- Replaceable Seat and Backrest Cushions
- Flame Retardant Upholstery - (Velour Cloth)
- Long Lasting High Quality Upholstery
- High Quality Durable Foam
- Suitable for 4,5 or 6 Point Harness
Nice build. Great choices of colors. Can never go wrong with Blk/Red/white.
Basic Sponsor
Basic Sponsor
Front Suspension
Rear Suspension
Corner Balance and Alignment
BBi Autosport Front & Rear Lower Billet Control Arm Kit
BBi Autosport Front Bump Steer Kit
BBi Autosport Rear Adjustable Toe Link
BBi Autosport Front & Rear Thrust Arm
BBi Autosport Front & Rear Adjustable Thrust Arm Bushing Kit
BBi Autosport Rear Upper Control Arm Kit
Please email us at Jerry@BBiAutosport.com or Sales@BBiAutosport.com to place an order or for all questions and inquiries!!!
Rear Suspension
- Improved two piece 996 GT3 lower control arm design
- Stronger than cast motorsport Cup arms
- Allows proper camber adjustment 996 & 997 Models
- Uses GT3 shims to adjust camber & lower control arm length (sold separately)
- High-strength steel alloy spherical bearings, completely serviceable unlike the motorsports arms
- Sealed monoball inner bearing
- Allows easy access to inner arm hardware
- Includes adjustable thrust arm bushings to adjust adjust caster and wheelbase
- A must have for all track and race enthusiast
- Each kit includes pair of 2 arms
- Fits both front and rear axles
- Helps eliminate bump steer by maintaining proper front end suspension Geometry
- Utilizes misalignment rod ends of the arm to provide maximum articulation
- Highly recommended for vehicles that have been lowered
- Each kit includes pair of 2 Links
- Provides additional rear toe adjustment
- OEM link is non adjustable and eccentric bolt provides limited adjustment range, causing excessive tire wear and handling issues.
- Helps maintain proper rear end suspension geometry
- Connects the Lower Control Arm to the subframe
- Provides precision caster adjustability
- Spacers included for setting stock or anti-squat and anti-dive configurations
- Each Kit Includes Pair of 2 Links
- Provides two eccentric mounting points
- Used to adjust for increasing or decreasing wheelbase, and adjustable caster.
- A must-have for extended lower control arms (GT3 control arms or eccentric monoballs) to correct for unintended caster change
- Compatible with all stock Porsche 996 and 997 lower control arms (including Porsche Motorsport Cup arms)
- Complete set of 4 (2 front & 2 rear)
- Link the rear wheel carrier to the sub-frame.
- Allow adjustment of track width and kinematic toe.
- Complete set of 4
Is this still available for sale? I love the build!!! Black on White wheels has always been a favorite of mine and the Red Pole positions are genius. They remind me of the seats in my F40. And i'm a huge fan of starting with a NB platform. I'm seriously considering tabling my project and purchasing this car. Best Josh
Basic Sponsor
- jerry
