Cam Adjuster Bolts Backing Out
#31
Just spoke to the shop, they verified my cam actuator bolts are perfectly intact and engine will be back in this week.
Never been this excited for spring in a long time.
#33
Premium Sponsor
PCA National Instructor
TPC Racing stats:
2023 Porsche Sprint Challenge 992 Cup Am Champion
2023 Porsche Sprint Challenge GT4 Pro-Am Team Champion
2022 Porsche Sprint Challenge 992 Cup & 991 Cup Champion
2020 IMSA GT3 Cup Challenge 2nd Championship
2018 IMSA GT3 Cup Challenge 2nd Championship
2016 IMSA GT3 Cup Challenge Champion
2013 IMSA GT3 Cup Challenge Champion
2006 Rolex-24 @ Daytona GT Champion
2004 Grand-Am SGS Class Champion
TPC Racing stats:
jayi836 (04-07-2020)
#35
Mine backed out right as I was out of warranty. Approx 32k miles. Porsche wouldn't warranty it but they did offer to replace the motor for only $65k assuming my core was okay. I said thanks but no thanks and had the motor rebuilt. It's been about 11k miles and no issues.
Dundon has a harmonic balancer to help correct the issue.
Car was never the same.
#36
Is this the best RL thread that aggregates the preventative solutions to this problem? Which gt3/rs models are susceptible to it? What are the costs of the different preventative solutions? Thx!
#38
Thanks for finding this thread, and posting to it hf1 (I'm pretty sure you are in the market for a RS, so I want to write this here, to ensure clarification....)
I remember reading through this thread about a year ago,... and recall coming away with the assumption that this problem with cam actuator bolts was primarily seen with LWFW and higher probability on the RS cars, not the Dual mass regular GT3's.
Is that a bad assumption?
TIA,
=Steve
TIA,
=Steve
#39
TIA,
=Steve
TIA,
=Steve
this off season my car is having a lot done (coolant lines welded, etc) and i have been going back and forth on putting in a LWFW or not while the engine is out and i still havent decided what route to go with these bolts because of it.
#40
Quit Smokin'
TIA,
=Steve
TIA,
=Steve
#41
excellent feedback Auto_Werks. Thank you for that. I am very close to Michael & Tom over at TPC, so maybe the M7 bolt modification will be something I have them take care of.
.... I guess something could be said for going "too far" in being proactive,... but another question (maybe for Tom) would be,... Can you do both a M7 bolt upgrade AND have it wire tied? (like FLTSPD refers in post #7).
Is that M7 bolt head big enough to drill a pilot hole through? ... or would that weaken the bolt head itself?
Also, Steve2k1116 above,... if you are already planning to spend the time & $$ to have the coolant lines done, and contemplating a LWFW, sounds like you should not let the actuator bolts get in your way to making that decision. If you're already going that far, then having a harmonic dampener installed &/or having the M6 bolts replaced/strengthened / locktite / re-torquing, should be a no-brainer. my .02
=Steve
=Steve
#42
=Steve
=Steve
my issue is i over analyze everything. most likely will just do everything but i want to be comfortable in my choice.
#43
So 996.2, 997.1, and 997.2 gt3 (with DMFW) don't have this problem, while 997.1 and 997.2 RS both do? Or is this just a 997.2 RS problem? No shop (most of them Porsche and GT/Cup car specialists) has ever mentioned anything about this issue with my 996 GT3. What "harmonic problems" do these engines have? First time I'm hearing about this.
Again, what are the preventative solutions and how much do they cost? Losing a Mezger engine over smth like this would not be "fun".
Robocop305 (11-25-2021)
#44
https://rennlist.com/forums/997-gt2-...cking-out.html
#45
Quit Smokin'
Symptoms are subtle... I saw one guy have a cam bolt failure on his RS, and it also had cracked the mount tabs on his alternator when he stripped the engine. That's a definite clue the there's a vibration problem when hard mounted parts are cracking. The 997.2 RS also has a recall on some fasteners in the intake tube that vibrate loose and ruin the engine. Also supposedly not an issue on the base GT3. If I remember correctly there were earlier generations of GT3 that would have the crankshaft pulley loosen up and fall off when a light weight flywheel is installed. It's bee a long time since I looked into that so I don't remember, but I think that was 997.1. You can also search threads on the aircooled cars and see where people had a hard time keeping the old 6 bolt flywheels to stay tight.
