Leatherique? Please help.
Happy to share. Followed the directions, larded it on all over. My car has leather everything, tons of exclusive leather everywhere.
I then park in the sun for 8 hours, windows closed. Steam bath ensues (CA sun!)
Once sun goes down I follow directions. Car is seemingly no cleaner, and removing all the gunk/product takes hours. On second application I have up and took to my detailer to remove all the residual leatherique. He said don't use this stuff.
Bummer as I bought the big kit on Amazon, will like give it away at the next C&C
Yeah, that would sour me on it, too. Definitely an atypical result, although it sounds like you did what the instructions say.
Too bad I don't live near you, I'd definitely take the extra off of your hands.
After two attempts at stripping, re-dyeing, and resealing, the spot is still slightly visible. Most folks would says it' "ok" but in bright sunlight it's not up to my standards. Next step, replacing the leather panel on the seat with "Porsche replacement" leather. Price is going up as you would expect.
I also had the dreaded inner door sills resurfaced. They look great but the new finish is more matte black than the original. I'm ok with it. The shop said to expect to redo this every couple of years, as I will likely just mark them up again. No protective covering that they can recommend. This is the cost of Porsche ownership if you are very particular.
Just put new N2 spec Michelins on the rear and a proper alignment. PDK and oil service is next, ($$$$) but repair and maintenance is still lower than my x5 diesel.
Peace
Bruce in Philly
I use goof off. Seriously.
If you have a guy who can re-dye the seat for a quoted price that's acceptable to you, then you have a free pass to try any or all of the methods suggested in this thread, right? Nothing to lose. Have fun!
I would give Leather Master product a try as well before replacing leather or seats. This stuff is apparently supposed to be safe on perforated leather/ventilated seats and the soft cleaner will apparently also clean out the perforated holes which causes the appearance of spotting when they get dark.
I used Mequires Gold Class leather cleaner and conditioner and it actually caused some spotting or discoloration as well. I believe I also saw a product on leather Masters that was intended for this very issues.
The spew remover may be designed to address exactly what you are experiencing.
http://www.leatherworldtech.com/Leat...r-p/lmspew.htm
You may even want to step up to the Leather Master Foam. I am using soft cleanser as much issues are very subtle and I don't want to risk damaging the dye.
http://www.leatherworldtech.com/Leat...er-p/lmsoc.htm
http://www.leatherworldtech.com/Leat...-p/lmfc400.htm
Some on here and other Porsche boards have said the foam worked great and removed spots from perforated leather seats that looked as bad as yours.
https://rennlist.com/forums/997-foru...eat-spots.html
You apparently need to follow up the cleaners with this conditioner to restore natural look as the cleaners will cause a matte look.
http://www.leatherworldtech.com/Leat...al-p/lmvit.htm
But using Leatherique on original Porsche leather is perfectly safe. My car not only has the all-leather option but it has natural leather. I was concerned about using the product on the natural leather, but after testing it, I found the product worked very well.
I have used it two or three times on the entire interior and have been very pleased with the results. It not only cleans, but removes shiny spots and leaves the leather with its original semi-gloss sheen.
Well, after reading through this thread, I would definitely be concerned about using any cleaner on leather that had been re-dyed.
Very nice! The Leatherique process must be followed to the letter. The longer Rejuvenator is on and the higher the ambient temp is the better. In the past I posted a negative opinion about it but I confess that was due to improper use of the product. I still like Leather Master, especially to maintain well kept clean interiors.
I'm interested to know, I need to do the leatherique on the natural brown interior of my recently acquired 997. Although a messy process, I've had great results using leatherique on my E90 BMW with the Oyster leather.
