I bought my 09' 4S two months ago. When cleaning it I realized there was some old dried up brake fluid staining on the inside of 3 of the rims. On closer inspection I noticed both front calipers have what appears to be the gaskets squishing thru. The brake fluid is full at max and there is not visable leaking.
Is this something I can remove and replace? I have attached a picture. Any info would be appreciated.
Sensor wires should look like this for the outward pad. Inner pad goes straight up and is captured by the tether on the bleed nipple cap initially then runs to connector plug.
