The heated seats in the 991
Hi all
I am in the process of purchasing a 2006 997. I just had it inspected and there are some minor things that the dealer will look further into. One of them is that the heated seats don't work. The dealer is "guessing" that heated seats in this model don't work unless the temperature outside is cold. Right now it is 75. He says that we won't know for sure until the winter. Doesn't make sense to me, anyone know anything about this.
ps: Not a deal breaker for me, I can live without the heated seats or fix them later, just curious.
The heated seats in my 2006 997 are definitely NOT temperature dependant. I press the button to turn them on and they heat up, regardless of the ambient temperature. If yours are not warming up there is something wrong.
That's what I am thinking. Thanks.
My best friend bought a certified used Jaguar many years ago. He took it into the dealer because his seat heater wouldn't work. They called him and told him that the driver's seat that the factory installed was a non-heated seat. The car was supposed to have heated seats and had two switches, but the power wire from the car just didn't plug into anything because the seat had no heating element.
My buddy said, fine, it's under warranty, go ahead and fix it.
So, weeks go by while Jaguar orders the seat and waits for it to come from wherever.
When he goes to pick it up, they presented him with a bill for a couple grand and proceed to tell him that even though the car was set up for heated seats, the passenger seat was heated and the original invoice listed heated seats, the car had come from the factory without a driver's side heated seat, so it wasn't covered under his warranty.
Needless to say, the issue was elevated to corporate and eventually, Jaguar let him take the car home without having to pay for the seat he should have always had.
Not only a funny story, but another reason to not buy from a Leith dealership.
The whole "I won't know until winter comes" is possibly the lamest response I've ever heard from a car dealer.
The seats, by the way, don't have any sophisticated thermostats that only allow them to work when it's cold outside. That's ridiculous and AFAIK, no car on the planet has such an option.
It may be a simple fix, but don't trust this joker to do it. In fact, don't trust him at all. What that really translates into is "Buy it, then GTFO and never come back."
heated seats work at all times-there is no temp dependency.
I just went through getting my 997 drivers side heated seat fixed-
it turned out to be a bad heating element. it was covered under my warranty-but I can tell you that this can get expensive if you go to a dealer
+ 1 million (for the 1 millionth 911 rolling off the assembly line)
Did you check the heating plugs under the seats? They can pop off when the carpets are vacuumed.
Even if they look to be connected pull them off and reconnect. That got mine going, thanks to a suggestion a member made to me a few years back.
What do you mean, having the ignition key in the console where the e-brake handle is seems totally normal. Add that to the absence of any sort of cup holder in the car and guess where the best place to set your drinks is - right there above the ignition key so that when the drink sweats, it all runs down into the ignition cylinder. In one respect, the positive to having it there is that if you have a number of keys on your keyring, your keys don't keep hitting you in the knee when you turn and they swing back and forth.
