GTS Cruise Control Retrofit
Yes, I've used the search function but can't find any helpful posts with regard to the 997.2, much less the GTS ![Frown](https://rennlist.com/forums/images/smilies/frown.gif)
My local dealer said there is no retrofit kit for the GTS but available for the Carrera 2/4/2S/4S, which seems odd. But Suncoast says the kit listed on their website (https://www.suncoastparts.com/product/CRUISEKIT.html) will fit the GTS, even though the website says it's for model year till 2008.
Does anyone know for sure? I don't want to order only to find out it does not work. I know it requires some coding work from the dealer after plugging it in.
Don't know if this is applicable, but I had it done on my ex-6GT3. Please note, this was for a 996. Got the retrofit done at the dealer where I had bought the car a couple of years ago. From the repair order:
Parts:
1 996-613-219-10-EWC, Column switch assy
1 PNA-721-043-00-040, Repair set K - #9600
2 PNA-721-043-00-063, Repair set 03 - #960
10 999-513-007-40, Tie-wraps ($2.45 ea!!!, what a crock!!)
1 PNA-721-043-00-122, Electrical housing #960122
$343 in parts, $225 in labor
NOTES: Installed column switch, and fabricated wiring harness. Coded and verified operations
Parts:
I got the parts from Suncoast https://www.suncoastparts.com/product/CRUISEKIT.html
Got the local workshop to fix it up and turned it on via the computer.
Works perfectly for those of you who are wondering...
