Question re: Plasti Dip
Old 04-27-2017, 12:05 AM
CHF3
CHF3's Avatar
Default Question re: Plasti Dip
Anyone tried it on interior finishes ? Specifically, I'm referring to the aluminum finish in the 997.1 PCM trim. I may paint it black, but wondering if plasti dip would work, preserving the option to return to alumalook stock finish later. Thx
Old 04-27-2017, 01:07 AM
ChicagoSpeed996
ChicagoSpeed996's Avatar
I just plasidipped tonight. I would say if it is a wear and tear surface, it won't last. But that's the beauty of it....it won't last and you can return to stock anytime.
Before
After
Old 04-27-2017, 03:55 AM
captainbaker
captainbaker's Avatar
Put it on in 2 or 3 coats medium thick. That way it will peel off when you want. Removing a light coat is a PITA.
Old 04-27-2017, 10:28 AM
Iceter
Iceter's Avatar
Plasti-dip doesn't hold up well on things that get touched or rubbed up against.
I Plasti-dipped my youngest son's electric jeep in camo colors. The dip has held up well on most of the jeep but the steering wheel, seat and door opening all started to look ragged very quickly.
Old 04-27-2017, 01:15 PM
CHF3
CHF3's Avatar
Thanks for feedback. Theoretically the trim area on the PCM wouldn't be touched often (mostly touching the buttons). Paint is the way to go, just not sure the impact on resale if not the original stock color.
Old 04-27-2017, 02:13 PM
vern1
vern1's Avatar
Just try the plastidip. I have it on my fan and temp switches (due to the dreaded peeling switches) and its held up fine for 2 years. Also did my winter rims last year and just took them off - no peeling which I think is pretty awesome given a Cdn winter...
Old 04-27-2017, 06:40 PM
mpath
mpath's Avatar
An alternative which I prefer is Autodip.
Old 04-27-2017, 09:14 PM
myw
myw's Avatar
do the rear diffuser section as well!!!
Before
After
Quick Reply: Question re: Plasti Dip
