RMS - Leak or Seepage?
Hey Everyone,
I am on the hunt for my first 911...
I just had a PPI done for a potential 997.1 purchase. It was done by a mobile mechanic who noted that there was seepage in from the RMS (photos attached).
I have not seen this car in person yet (a few states away so was relying on a PPI to work out if i wanted to take further)
From the the community's perspective does this look like 'normal' seepage or a leak that would need to be immediately fixed?
Craig
Craig
Your 2nd pic looks like seepage migrating along the threads of the bolts used to hold the case halves together, which is often misdiagnosed as an RMS leak. If so, it is easily remedied by removing each bolt, cleaning the threads, putting some oil resistant RTV/silicone on the threads, re-installing, and tightening to the proper torque, then moving on to the next one, doing only one at a time so the case doesn't come apart. If the leak looks like what I show in these pictures of my car, that should solve the issue.
My leak was bad enough that after a high RPM spirited drive, it would actually create a small puddle on the floor, but not after a normal drive. It's been bone dry for a couple years now after I did this repair procedure. If it is an RMS leak, you should have someone pull the seal and use the Porsche measuring jig to make sure the opening is still in spec - if not, it will always leak. If it is in spec, a new seal should fix the leak, but once you get that far in, if the car has the small IMS bearing (early 2005s), that should be replaced with The IMS Solution.
Al Allen (04-06-2022)
Op - It may not make any difference to you at this point, but Porsche defines a leak when the fluid hits the ground (or under body panels). Seep is anything else. I know this from a leak I once had and could not get warranty coverage until their criteria was fully met.
