Smoothest Street Coilovers
#46
Not sure I completely follow but will re-read. Made me think to measure fender to runway with the car lifted just to see if there’s anything off there without the suspension engages assuming the bridge jack engages perfectly.
#47
If your having the car aligned yes you should have it measure from the point of the suspension under the car, but if you setting up the ride height to get a base line from the fender to the ground works fine. It’ll probably get readjusted again by the alignment guy … or gal
#48
Turned out the rears were off by 3/16" on the coilover itself, so adjusted that. Tweaked the front by 1/8" also and now everything is within 1/16th according to the fenders and spot on from those measurement points.
Will schedule alignment in a few weeks. Thanks for the help.
#49
