WTF??
First - never use a car wash.
Second, check your optical connections, something is loose.
Eric
Chief Plug Guy
BumperPlugs.com
2022 GT3 Touring 6sp
2009 997 Turbo Cab 6sp
2018 M2 6sp
Gone but not forgotten
2004 C4S Cabriolet
1999 C2 Cab
Eric
Chief Plug Guy
BumperPlugs.com
2018 M2 6sp
2004 C4S Cabriolet
1999 C2 Cab
I'm thinking when the frunk is opened water hit the CD changer in there.
Worked just fine when I left and drove for a bit. Stopped at store and 10 min later I get that.
Hope it's just connections. Uggg
Took too dealer, car being CPO'd, warriented the PCM. The service writer told me that the head units from 2005ish to 2015 ish were manufactured by Panasonic and there is an impending suit/litigation (supposedly I haven't been able to verify) and that Panasonic vs XM software is/was the issue. Week and a half, they had my car, fixed it and he did say that he's had the problem be repetitive on the same car before.
Plus, I've seen other makes have the same issue (not with the battery dying, by radio/nav/sat, Also manufactured by Panasonic. Maybe this is old news, but I couldn't find this problem via search in this 997 forum.
After disconnecting the battery for the night the gremlins are back and the PCM still says the same thing. Really sucks for this to happen.
Can't believe a connection came loose all of a sudden either. Replacing the PCM doesn't seem to the the answer either as it's working fine with everything else. Just no stereo.
I can only think that water got into something at the car wash.
While there are good reasons to not use a car wash damage to the car's electronics is not one of them. The interior of the car should remain dry when run through a car wash just like it should remain dry when you wash the car at home or the dealer valet service washes the car after servicing or you drive the car, park the car in the rain.
Check for signs of water where it shouldn't be. Most often the cabin floor gets wet from blocked body water drain. Less often from water leaking in through the door bottom the water in the door from a failed membrane.
Unless you are lucky and find a smoking gun that points to the reason for the errors I'm thinking you probably need this diagnosed by a tech with access to a Porsche diagnostic computer. With this he can query the PCM/navigationi system for any errors and from these know what's going on.
You can remove the PCM unit and send to Becker Audio for diagnosis and repair. Had this happen on a Cayenne once. Took a few weeks to get the unit back. Cost was something like $500 which was about $2500 cheaper than a new PCM. Porsche dealer won't repair it. They will only replace it. Do a google search for Becker audio.
