Purchase advice... 997.1 or 997.2
My '09 S with PDK is a bit over 49k miles. I bought it with a little over 44k last summer, so it's my toy and not DD. Drive my old f150 4x4 with 143k miles for that. When shopping I was looking for 997.2 only. I considered some non S 991 but just flat think the 997.2 is a sweet spot between design, size and mechanical issues. It has always been a Texas car, very well maintained and prior owner seems to have among many upgrades changed the thermostat. It is very cold natured and slow to warm up. So, I'm very easy on her until up to temp. I've taken a couple of trips besides around town and I watch the oil level religiously due to that being an early sign of scoring.
This is Porsche #7 but my first 911. Get the 997.2. The S is quicker than I need. I think for the $ you would be very pleased with a low mileage non S 997.2.
JUST my thoughts, I have two 09's wouldn't consider going older. both of my have about 65K miles and both got the 60K service. I have zero issues with either one. (except my wife just had a fender bender in our company paring lot). anyway I paid 40K & 42K for my cars. well withing your budget. My cars are not S, however you can find 09 S cars between 43K-48K under 65K miles
good luck
good luck
ParkslopeDope (09-13-2020)
Words of wisdom no doubt. I especially like the idea that depreciation will be minimal. Any thoughts on whether the model year really matters? 2005, 2006, 2007 or 2008?
The 997.2 non S is still the 9A1 motor but less displacement and HP. Still no intermediate shaft. I also seem to remember on that very long and involved excellent thread between Hartec in the U.K. And Jake @ L&N the 3.6 might be less prone to bore scoring due to more meat on the walls? Can't recall. The thread is worth a read regardless.
I'm thinking you will be happy with the 3.6 performance wise. My S also has PSE with the Sharkwerks X pipe and the Fab Speed comp dual cone intake. It's just way quicker than anything you need ( like we use that as a rational gauge of decision making ) and only gets me in trouble. I'd say drive some examples.
I went 997.2 non S and I am very happy with the decision. There have been a couple other threads on this recently, and it seems the two big factors for 997.2 buyers are lack of IMS and PDK. PDK doesn't seem like a big factor to you, but ito performance, the 997.2 non S is pretty much on par with the 997.1 S. Your mileage numbers seem pretty extreme. I've barely seen a 997.2 with anywhere near 100k miles, and the pricing wasn't too much more when I was comparing. You should be able to pick up a nice low-mileage base 997.2 at or a little over 40k, which considering the car is a smoking deal.
+1 on the non S 997.2, in particular with manual transmission. Even with the smaller engine, the shift points come up so quickly that it's difficult to nail the perfect rpm.
I debated base vs S quite a bit before I purchased my base, and I ordered my car, so there weren't any other build factors that came into play. I have never regretted my choice. Mike
Let me expand upon the discussion by suggesting I keep the car for 10 or more years. Would this make the 997.1 or 997.2 more appealing? Again... I prefer DIY maintenance and repairs that don't require engine drop.
To do a timing chain on the 997.2 direct injection, you have to remove the motor. Now this isn't likely to be needed until 150-200k miles, but just a thought, the 997.1 motors are much easier to work on and therefore cheaper labor costs
if you want to retain any value long term the Base cars are NOT the car to have period.....
plus if your someone that likes to mod things, add parts, make things better etc start with the S IMO. If your OK with leaving things alone (I could NEVER own a Porsche not modify if) the base may work for you. The base is a wonderful car on many levels for the right owner....
you can buy a 997.1s for less then a base 997.2 and have the car be a higher optioned car. With the savings go buy a fidelity warranty and do the IMS. Now you have a car covered for 5 years under warranty and has the IMS done. This may cost you about 5K. Add that 5K ticket to the price of a 997.1s and your at about the price maybe a bit more then a 997.2 base and now you have wiped the IMS issue out and have a car under warranty for 5 years!
ask me how I know? What I did.... or similar at least. My car just had the IMS done by Jake Raby prior to my purchasing the car, bought the car and picked up a 6 year fidelity warranty for like 3k for piece of mind.
I hear you. You guys aren't helping much! Ha. Pretty even split between the two choices.
Depends on your budget but the non-S .2 cars are at least $10K more than .1 S cars. If you're going to keep it a long time I'd say .2 but if you're in and out in a couple years the .1 car will likely depreciate less since it's already had the bulk of its depreciation.
