50/50 coolant?
Old Feb 18, 2017 | 01:08 PM
malexgcab's Avatar
malexgcab
Default 50/50 coolant?
My coolant is just under the MIN level. Is the coolant concentrated or 50% water mix?
Any harm toppling off with water?
I don't mind buying a gallon for a small amount but it's a waste if I won't use the whole gallon.
I'm considering bringing it in for water pump replacement in the summer.
Old Feb 18, 2017 | 01:14 PM
extanker's Avatar
extanker
plain old water will be fine. do not be surprised when this thread goes 3 pages on the perils of doing it though. bring it tinkerbells
Old Feb 18, 2017 | 01:27 PM
Lvt19672's Avatar
Lvt19672
It's already been broughten
cool flash's Avatar
cool flash
Car holds more than 30 quarts of coolant. Adding a little bit of plain water will not have any effect at all on the concentration of coolant to water.
I hope this clears things up a little bit.
CF
Old Feb 18, 2017 | 01:40 PM
dasdman's Avatar
dasdman
I have always used distilled water, just to eliminate any chance of mineral deposits. That being said, I agree, adding a little water won't hurt anything.
Old Feb 18, 2017 | 03:12 PM
jchapura's Avatar
jchapura
Are you guys from the devil? Plain water? I use double distilled, DI from fresh resin deionzers. No wonder you're getting bore scoring and IMS failures left and right...
Seriously though. Type of coolant is more important (don't want gelling). FWIW, I use 60/40 (water/coolant) since I don't have much freezing chance and the physical properties say I'll get better heat transfer.
Old Feb 18, 2017 | 04:04 PM
jhbrennan's Avatar
jhbrennan
You can buy in smaller quantity -
http://www.suncoastparts.com/product/00004330147.html
Old Feb 18, 2017 | 04:11 PM
1990nein's Avatar
1990nein
Old Feb 18, 2017 | 06:14 PM
KNS's Avatar
KNS
Originally Posted by Pho King Fast
In general you should maintain the water/coolant mix, as the ratio affects boiling points and freezing points.
In general - yes. Adding 6-8 oz of distilled water is perfectly fine.
Old Feb 18, 2017 | 07:50 PM
malexgcab's Avatar
malexgcab
Thanks for the info guys.
Old Feb 18, 2017 | 08:07 PM
extanker's Avatar
extanker
do you think they are done yet ?????? ....they have not yet asked you if you have had your tap water sent out for analysis before putting into the system or to have it flushed/purged/burped after changing your oil with DT40 ..............think i am kidding....wait
Old Feb 18, 2017 | 10:24 PM
Para82's Avatar
Para82
Top it off with Distilled Water only - shouldn't take much.
Old Feb 18, 2017 | 10:57 PM
malexgcab's Avatar
malexgcab
Old Feb 18, 2017 | 10:59 PM
Lvt19672's Avatar
Lvt19672
Old Feb 19, 2017 | 08:04 AM
Rikky001's Avatar
Rikky001
Did you find the leak? Think that is the question to answer.
