cargraphic front lift kit - anyone have this?
#31
Update: I sent back the control module to Cargraphic. They kept it for a month (no idea why). It took quite a few emails to get them to ship it back to me.
The good news is that the kit actually works now. But it only lifts the car 34 mm at the wheels (Not 55mm, which is what Cargraphic mentions in their brochure.)
What a nightmare. I ought to do a full review when I get a chance.
#32
I find that with mine, if I press the button as I'm approaching the driveway or speed bump I'm trying to clear, if I give the car a little gas to unweight the front, it will kick the compressor back on and gain additional clearance height - vs how far it lifts if the car is static. I haven't actually measured the height I get at the center of the wheel vs the at the lead edge of the front bumper (which is where it really matters to me), but maybe I can do that next time I take the car out, which might be tomorrow.
During install, I also lubricated the metal sleeves that the airbags ride on with some Teflon spray lubricant and can see where the better the rubber bag can slide on the metal sleeve, the more lift you may achieve and it will probably rist and fall faster than if there is more friction between those two surfaces.
#33
#35
I ran the test for you today, measuring the left front wheel arch, center nose at bottom of bumper, and right front wheel arch all at the initial setting, then hit the AirLift button with the car stationary, waited for the compressor to stop and measured the 3 locations again, then lifted up on the bottom of the front bumper to simulate the rolling throttle blip technique I mentioned, and recorded the values again.
Left Front Wheel Arch - 26" > 26.5" > 27.5"
Right Front Wheel Arch - 26.25" > 26.675" > 28"
Nose - 4.75" > 5.5" > 7.125"
so, it looks like with the car stationary, I get about 1/2" of lift at the wheelwells and 3/4" at the nose, but with the throttle blip unweighting the front where the compressor kicks on again to full lift, I get 1.5"-1.75" at the wheelwells and 2 3/8" at the front nose, which explains why no more scraping the bumper since installation of the kit.
You might try backing into your garage so you can create the weight shift that maximizes the lift if that's a possibility.
Anyway, hope the information helps.
Pete
Pete
#37
Very interesting measurements, thanks for taking the time, Pete!! So it sounds like your lift kit is only giving you a 1/2" = 13mm rise. That's way less than the 55mm that Cargraphic claims!
I might try your idea of unweighting the car - makes sense. Unfortunately, if I back in, something in the rear scrapes.
#38
I have the kit with the roof console switch installed. Unfortunately it is not reliable. Sometimes I press and hold for 2 seconds and it works and other times I press for 10 seconds and nothing happens.
With the A/C on and or radio on I cannot hear the compressor pump. I'd love to wire in a small red led light (hide in the instrument cluster) that turns on when the lift is up.
#39
