997.2 center console removal
Old Dec 25, 2016 | 04:39 PM
gwinder's Avatar
gwinder
Default 997.2 center console removal
I've found some threads on removing the center console which I'm going to send to Classicleather to have covered during the winter. My question is will I still be able to drive the car without the center console?
Gary
Old Dec 25, 2016 | 04:44 PM
semicycler's Avatar
semicycler
Yes, but you will likely get an airbag light on the dashboard due to the passenger seat weight sensor light being disconnected. If you have Durametric it's easy to clear. If not you will need a dealer trip though.
Or disconnect the aribag light from the center console and reconnect it to the car before putting the key in the ignition.
Old Dec 25, 2016 | 04:56 PM
DC911S's Avatar
DC911S
If you have the iPhone adapter you need to disconnect that too.
Old Dec 25, 2016 | 08:52 PM
gwinder's Avatar
gwinder
Thanks...probably best not to drive it...a trip to the dealer will cost more than covering the console
Old Dec 25, 2016 | 11:05 PM
kellen's Avatar
kellen
It's the passenger airbag light that trips it. Just remove it from the console before you send it out and connect it off of the console so you can drive again.
Old Dec 26, 2016 | 03:34 AM
rherring's Avatar
rherring
Please post pictures of your center console after you get it back from Classic9Leather. Their prices seem to be very reasonable.
