Removing PDK Paddles from Sport Design Steering Wheel
Old 05-23-2019, 04:42 AM
Zoefhaus
Zoefhaus's Avatar
Originally Posted by wjk_glynn
BTW, here's a post with another technique for pulling the front trim from a PDK Paddle wheel...
https://rennlist.com/forums/997-turb...l#post15844334
Karl.
Excellent cross-posting Karl
This way all (or most) info can be found in one location.
It looks like the probability of breaking (some of) the tabs is quite high, so I'll probably pass...
Old 06-08-2019, 04:40 PM
Zoefhaus
Zoefhaus's Avatar
So I decided not to take the risk breaking anything.
I am putting the sport steering wheel design up for sale, for (what I believe is) a very reasonable price.
Here is the link to the ad: https://rennlist.com/forums/market/1147298
Old 06-19-2019, 05:02 AM
Zoefhaus
Zoefhaus's Avatar
Updated: yesterday I felt courageous and decided to give it a try anyway
It actually worked out pretty well:
- I used the "flossing" method with a regular piece of thin rope, and was able to remove the silver trim
- As expected, a few of the tabs broke, but I was able to glue them back together easily
- Unfortunately I was unable to avoid 2 or three light scratches on the silver trim (don't exactly know how that happened), but these are very thin and barely visible from a bit of distance
- The PDK paddles come off easily as well, just 2 bolts.
However, now that I have seen the wheel without the paddles, I am not sure I like the look from the sides.
The gaps/holes on either side due to the removal of the paddles are bigger than I thought they would be...
I will upload a few pics over the weekend.
That leaves with me with two choices: either my OCD accepts that there are holes in the sides of the steering wheel and other than that I have a great-looking wheel, or I still sell it at a discounted price given the light scratches.
Choices, choices...
Old 06-19-2019, 05:29 AM
Zoefhaus
Zoefhaus's Avatar
I have changed the for-sale ads to reflect my previous post.
Old 06-20-2019, 04:47 PM
Zoefhaus
Zoefhaus's Avatar
Pics of the scratches:
There is a minor scratch on the left spoke, and 2 minor ones on the right spoke (above and below the little "screen").
From a bit more distance (3rd photo) you'd be hard pressed to notice.
Old 03-11-2020, 02:48 PM
Joe Spicer
4th Gear
Joe Spicer's Avatar
Hiya, I wondered if you still had the pictures of the steering wheel with the holes where the PDK paddles were? I'm in the same position and can only seem to find PDK wheels at a reasonable price!
Old 03-11-2020, 06:20 PM
Zoefhaus
Zoefhaus's Avatar
​​​​​​I am afraid I don't have those pictures anymore, but believe me, the holes underneath the paddles are quite large.
Without the paddles the wheel looks... unfinished.
If you could have some aluminium cover plates made, that would do the trick though.
Or just wait until one of those very rare manual sport design wheels comes along
Old 03-11-2020, 07:09 PM
Joe Spicer
4th Gear
Joe Spicer's Avatar
Thanks for the reply, looks like I'll hold out a little longer!
Cheers
Old 03-12-2020, 08:55 PM
arandazz
arandazz's Avatar
If anyone converts a PDK wheel and has a left over downshift paddle - I need one. The switch on mine has failed. PM me.
Old 03-30-2021, 10:54 PM
wjk_glynn
wjk_glynn's Avatar
...I wondered if you still had the pictures of the steering wheel with the holes where the PDK paddles were?
​​​​​​...believe me, the holes underneath the paddles are quite large.
Agreed. Here's what that hole looks like with the switch removed.
Karl.
The following 2 users liked this post by wjk_glynn:
tegraphile (03-30-2021), Zoefhaus (04-20-2021)
Old 03-30-2021, 11:44 PM
tegraphile
tegraphile's Avatar
Nice attempt. Given the rarity of manual sport wheels, could be something to look into.
Old 03-31-2021, 09:28 AM
nicogri
nicogri's Avatar
Maybe it will be possible to 3D print a blanking plate in black to put on that hole so it hide it kind of nice and beeint reversible
Old 04-18-2021, 02:05 AM
Rodo Troche
Rodo Troche's Avatar
hi do you have any other link for the agency video?
Thanks!
From the images you posted, I was able to find an original sources for others' reference. Here's a link to that video showing how to pull that trim (jump to the 5 min mark):
https://www.youtube.com/watch?v=d1oyA61kC5c&t=5m
And then here's a link to the Agency Power webpage referenced in that video...
https://www.agency-power.com/how-to-...teering-wheel/
Karl.
Old 04-18-2021, 10:27 AM
wjk_glynn
wjk_glynn's Avatar
It wasn't a video, it was a writeup on their (apparently now defunct) website.
By chance I had saved one image from their site as follows.
It shows where to work in the 0.5 mm carbon-fiber-string in behind the trim (the red slash), and then work it back as far as you can (the red dots, though in practice you can't get it as far back as the dots imply), then pull out that wing of the trim a bit. Repeat the procedure with the other 2 wings (blue arrows), pulling each out a bit at a time, until the whole trim piece comes out. This requires significant force, so go easy a bit at a time or you could break a wing.
Karl.
PS: See also @Zoefhaus Post #18
Quick Reply: Removing PDK Paddles from Sport Design Steering Wheel
