PCCBs from an 997.1 on a 997.2 GTS?
'looking for confirmation that PCCBs from a 997.1 Carrera S will fit on my 2011 Carrera GTS? I looked up the part numbers in the PET and they look the same, but maybe there is something I'm missing. Thanks.
What year .1? '05s used 350mm front and rear. Fronts on the later cars got larger, like 360 or 380 mm.
Fitment:
• Turbo (2001-2005) & (2006-2012)
• GT2 (2002-04) & (2007-2009)
• GT3 (2002-04) & (2006-08)
• Carrera or Carrera 4 with Ceramic Brakes (2009-12)
• Carrera 4S (2002-16)
• Carrera S Models (2005-16)
• Carrera GTS Models (2011-12)
• Carrera Speedster Models (2011-12)
• Panamera S or Panamera 4S
• Panamera Turbo or Turbo S
Does your GTS have center lock wheels - that may cause a difference.
Here are the part #s off my actual rotors from my '05 C2S. These are the 350mm ones at all 4 corners and believe they were a carryover from the 2004 996 Turbo and 2005 996 Turbo S based on the part #.
DF 996.351.031.04
PF 996.351.032.04
DR 996.352.031.04
PR 996.352.032.04
DF 996.351.031.04
PF 996.351.032.04
DR 996.352.031.04
PR 996.352.032.04
Rocky Mountain High
The 997.1 turbo ceramic front rotors are 380mm. I think they are 350mm on the C2S.
The yellow 6-piston calipers take slightly longer mounting bolts than the red 4-pistons as well, or consider it an opportunity to mount a caliper stud kit from Rennline, World Motorsports, etc especially if you'll be tracking the car and changing between street and track pads more frequently.
