Battery drain issue
Old Nov 6, 2016 | 10:12 AM
  #46
jowniofownio212's Avatar
jowniofownio212
Really confused now,
followed the tests on the page he page you listed and all looks good:
test 1: 0.05v
test 2: 0.4v
test 3 and 4 could not be done due to there not being the +be jump terminal in the engine bay on the 997. How else can I do this test? I have looked at the +be terminal in the fuse box in foot well and this is strange but seems to be ground and has 60ohms between this and 0v of battery.
test 5: 14.1v which says my alternator is good?
i have a 0.25A drain on battery which is normal but still have starting issues after leaving it for 2 days?
really confused now :/
Originally Posted by Ahsai
I assume the 12.9v was measured at the battery (best case)? If it was measured at the back of the alternator, then the alternator is bad.
They are just 3 steps away from identifying the culprit.
1) Measure the voltage directly at the back of the alternator (with some load such as low beam and a/c ON). it should read ~14 to 14.5v
2) Measure the voltage drop between the back of the alternator output and the battery positive post
3) Measure the voltage drop between the alternator case and the battery negative post
You cannot measure the resistance of the cable directly with a regular multimeter because the resistance is so low. Bad cables will show up in 2) and 3) if they see >0.5v drop.
I know that for 996 (most likely for 997-1 too) the voltage at the battery should be 13.5v to 14.1v (with low beam and a/c ON) and engine fully warmed up. At the back of the alternator, it should be 13.5v to 14v.
See more comprehensive test cases here http://www.renntech.org/forums/topic...comment-260718
Old Nov 6, 2016 | 10:28 AM
  #47
Petza914's Avatar
Petza914
I'm no EE, but In this case, does voltage really matter? Shouldn't you just be looking at the amperage draw across a fuse or circuit when everything is turned off to find the culprit?
Old Nov 6, 2016 | 12:02 PM
  #48
Ahsai's Avatar
Ahsai
If the tests were done as prescribed such as warmed engine and low beam and a/c ON, your cables are fine, your alternator is a little bit low but not bad. What's killing your battery is the 250mA draw. Normal draw should be less than 50mA, depending on theboptions installed on the car. Some cars draw much less than that.
​​​​Seems to me you should focus on the parasitic drain.
test 1: 0.05v
test 2: 0.4v
Old Nov 6, 2016 | 12:04 PM
  #49
Ahsai's Avatar
Ahsai
The OP mentioned 12.9v measured (at the battery?) with and without load. That is quite low (ask any mechanics) hence the investigation of the alternator and the cables.
Old Nov 6, 2016 | 04:24 PM
  #50
jowniofownio212
sorry for confusion, I have a battery drain of 0.05A not 0.25A. Is it possible to do tests 3 and 4 on the 997 as there is no +ve terminal or do I use the one in the fuse box?
Old Nov 6, 2016 | 06:01 PM
  #51
Ahsai's Avatar
Ahsai
997 should have a cable connection point at the transmission tunnel. You can use that connection point but I won't have a good guidance of numbers for you.
Test 1 says your ground is good and has minimal voltage drop. Test2 says you lose 0.4v on the positive side. Your alternator measures 14.1v so you would expect about 13.5v at the battery. You also said the shop measured 12.9. Even though we can't compare these measurements directly as they were taken at different times seems you still have 0.5v unaccounted for between the alternator and the battery?
If your drain is truly 50mA, that's on the high side but not way out and definitely won't drain your battery enough to cause you starting issues in only 48hrs.
​​​So things don't add up, literally.
Old Nov 6, 2016 | 06:06 PM
  #52
Ahsai's Avatar
Ahsai
Btw, this is a very handy and accurate tester I always recommend ppl. It has to be this one and not something that looks similar. It should help you in this case.
https://www.amazon.com/INNOVA-3721-B...ds=INNOVA+3721
Old Nov 7, 2016 | 11:18 AM
  #53
neanicu's Avatar
neanicu
OP,at this point it sounds like user error. By that I mean you're missing something when running the tests. You should take the car in to get it looked at by a Porsche specialist : either a trusty dealer or a well rated Porsche independent. They'll charge you 150-200$ the most but you'll know if there's a problem for sure,no guessing.
Just my 2c...
Old Nov 7, 2016 | 04:15 PM
  #54
Yet anothercrisis's Avatar
Yet anothercrisis
Just my 2c...
Here is a thought....I had a very similar problem on my 12 C2S. The problem seemed intermittent as I could measure and test all day and find nothing. Then as soon as the next day the battery might be dead if I didn't put the car back on the trickle charger. I got in a habit of hooking up the trickle charger every time I brought the car in from a drive. Eventually a week before the warranty ended, I took the car in for a final warranty service and mentioned the problem along with my "end of warranty list of small stuff I didn't like" to the advisor. The mechanics actually took time and found the problem. It turned out to be a bad wiring harness. A short circuit was intermittently occurring in the passenger air bag circuit. One of the pins was not making solid contact. The solution was a total wiring harness. Total!
I realized after the harness actually finally arrived from Germany that the wire harness is one of the first items installed as the car is constructed. Warranty covered the expense and the guys did a great job. After all was said and done, I couldn't tell that they had been in my car, even though I know that it was gutted. The car is still going strong after another year plus and I am a very happy camper.
Another benefit I soon discovered is that even the PDK works better. I had a significant pause or delay in shifts sometimes (again intermittent) that caused me to feel that the tranny was not going to shift gears. Without an upgrade or software, the new wiring harness seemed to solve that problem too as it has not happened again since the harness was replaced.
Good Luck
Old Nov 7, 2016 | 04:38 PM
  #55
jfort's Avatar
jfort
Veteran: Navy
amazon link did not work
https://www.amazon.com/INNOVA-3721-B.../dp/B000EVWDU0
Old Nov 7, 2016 | 05:00 PM
  #56
Ahsai's Avatar
Ahsai
Please try this https://www.amazon.com/INNOVA-3721-B...ds=INNOVA+3721
If it still doesn't work, just search for INNOVA 3721. It's only ~$13.
Old Nov 7, 2016 | 05:13 PM
  #57
Ahsai's Avatar
Ahsai
See post#34 here for how to use the tester effectively.
https://rennlist.com/forums/996-foru...l#post12614785
Old Dec 17, 2019 | 03:33 PM
  #58
curt997tt's Avatar
curt997tt
Default battery drain over night PORSCHE 997.1TT
AFTER SITTING IN MY CAR FOR AWHILE AFTER SHUT AND REMOVING THE KEY I HEAR MY RADIO CONTINUE MAKING A SOUND SIMILAR TO A CD EJECTING!! OVER AND OVER AND OVER! CERTAINLY ENOUGH TO KILL THE BATTERY OVERNITE!!! I HAVE TRIED MANY DIFFERENT WAYS OF LOCKING IT OR NOT LOCKING IT. IT WON"T STOP CYCLING AND KILLING THE BATTERY. HELP!!
Old Dec 18, 2019 | 09:43 PM
  #59
ALEV8's Avatar
ALEV8
My Porsche tech thinks the long battery cable in my car needs to go. I was sure the PO replaced it already at RUF along with alternator at 82k mi.
My dash or PCM has a soft rapid clicking that sounds like a teletype machine tapping out a message or Morse code.
I have a QR with a Momo 69 wheel in the car and if the noise starts up, I remove the wheel and get up close to the gauge cluster to listen.
I am 99% sure it's coming from the PCM. Not really sure when it started as the stereo cover up the noise. I chalk it up to a dying PCM.....I do have battery drain but i drive the car daily in short hops most of the time and some 30-40mi highway runs maybe 2-3x/wk.
Battery stats:
RED Optima battery maybe 2 yrs old max.
Using the Innova plug in meter Aloha refers to:
12.250v hit unlock drops it to 12.15-26v sitting before start up.
9.9v during crank.
13.9v driving.
12.41v after a 2 mi quick coffee run then home, lock doors, watch meter as car slumbers.
I do not lock the car in the garage ever. The numbers above reflect my charging the battery fully yesterday with the Porsche branded charger.
Old Feb 23, 2021 | 06:02 PM
  #60
Will911's Avatar
Will911
3rd Gear
Hello All, New here, glad i found this forum
2010 Carerra S with 24000 Miles, hardly driven... purchased new battery from AAA 6 months ago, this thing dies overnight. had a porsche auto shop do a diagnostic and they tested the battery and alternator and its all good. was told i may have a parasitic draw and to find it they charge $175 an hour with no guarantee how many hours it will take to find the problem. i see many here have had this issue, what has worked for you? thx in advance
By Verdad Gallardo | 2026-04-28 19:00:17
