Help - Brake fluid change - dumb!
2009 C2S 101K miles
I was about due for my 2 year brake fluid change and I did something dumb. I ran out of brake fluid before I finished the job. I had a 1 liter can that I thought I had used only half last time... well I guess I used more than that! What a dope.
Anyway, the reservoir is full of new fluid and I did two wheels but could not finish the last two. I will order another can of the stuff and finish next weekend, but a question:
Does the fluid "circulate"? In other words, the fluid in the lines just kind of push back and forth don't they? So the only mixing of old and new is just what was in the top of the lines at cylinder .... in other words, no big deal... if I wanted to be super picky, I would suck out the new fluid and toss it, pour in some new stuff and drain the last two wheels. Or, just drain the last two wheels and top off. What say?
Comments?
Peace
Bruce in Philly
Comments?
Peace
Bruce in Philly
After you get through this, be aware that you shouldn't use brake fluid from a previously-opened container. Brake fluid is hygroscopic (attracts water) and this leads to water in the system, and the heat boils it off (changes state) and that gas generation in the brake system causes a soft pedal.
Peace
Bruce in Philly
I understand this but don't believe it to be an issue. I had the can open for only a very short period of time, then sealed it up. I can't believe the integrity was compromised to where it is no good anymore. Just my opinion but I am open to being swayed. Peace Bruce in Philly
Question: While I am changing pad and/or rotors, can I bleed the brakes simultaneously using my Motiv brake bleeder? Would I need to disconnect it each time I move to the next wheel because I will be compressing the caliper pistons? May be a silly question but I'm still learning - I hope...
I ordered this Motive product from Pelican Parts about 10 years ago for my 930 and makes flushing a quick one person job.
Requires crimping fluid overflow line and using fresh fluid. I usually just left the unused fluid in the container sealed off and used it later without issues unless I was switching fluid color.
Haven't tried it yet on the 997 but specs say it will work.
http://www.pelicanparts.com/Porsche/...EDR_pg7.htm#75
Peace
Bruce in Philly
Peace
Bruce in Philly
http://www.stoptech.com/products/str-brake-fluid
http://www.onallcylinders.com/2014/0...e-brake-fluid/
The first is simply an information post from a major manufacturer indicating that their steel cans have a 25% longer shelf life (unopened) than plastic containers.
The second mentions the author contacting fluid suppliers about the unopened shelf lives and getting answers of 2-5 years (or unlimited for one maker).
My conclusion is that if unopened have best by dates then anything opened has a much shorter timeframe.
For me, this does not equate that exposed fluid is now unusable but simply it has some level of water absorption. I would consider how the fluid was stored (temp or environment, dry or rainy climate, and length of time).
Interesting stuff.
Regarding shelf life dates. I am intensely wary of them. In my past, I am aware of a famous, global food company attempting to improve their distribution system, improve discipline on distributors, and sell more product (desires that virtually every large organization have). They did this by simply shortening the shelf life dates on all their products. Worked famously. I say famously as it is a common tactic for virtually any product. What was started as a tool to ensure quality for customers has evolved to be an established technique for improving the bottom line.
Peace
Bruce in Philly
Peace
Bruce in Philly
Well then there is another option if you like to test things. They make moisture testors, I have no idea how reliable thay are.
https://www.amazon.com/Brake-Fluid-Tester-calibrated-fluids/dp/B005HVG4GQ
I saw some references to test strips, but it looked like they looked beyond moisture.
