997.2 GTS Brake Wear Light On
Changing your own brake pads at least once should be mandatory for 911 owners... Just kidding. If having the dealer put on $300 worth of unneeded brake pads for $800 makes you happy, go for it!
As stated earlier, brake pad change is a relatively easy DIY. I'm not much of a driveway mechanic and I found it pretty easy and straight forward. Give it a try...
