18'' tire sizes?
RE-71R is my first choice it seems but hopefully there will be more sizes available by spring.
ATSR, totally go 245 if you'll autocross it. I'm not feeling much understeer on track (plenty of time to turn) so 245 wouldn't make much difference to me but totally do it for autocross.
My buddy (also 997.1 S) is running MPSS them for autocross and they are all right if you're in it for fun. You won't be too far behind the more aggressive setups. Running 245 in front with low pressures (32- psi) and high pressures in rear (36+ psi) should dial out some understeer as well. If you won't autocross, I wouldn't bother.
