997 Roof Drip or Vandalized - Denver Airport
I wouldn't do anything to it until the insurance person at the Airport looks at it. Might as well get a fat check first before you do anything. Then do a little experimenting or have a professional do something. You could end up screwing it up to where they say they won't cover the damage now.
Try Steve's Detailing in the Tech Center. They do a nice job. I was just there on Friday having my car hand washed for the weekend.
FWIW, I've stopped driving my 997 turbo to the Denver Airport. There's so much debris on I-70 that I seem to get a windshield chip or a paint chip every time I drive down there. The last time I did it, a rock hit my hood and it went through the clear bra an into the paint. Grrrr.....
If it's really bad, Stuttgart Autobody is where I took my Cayman S for a little TLC. They weren't exactly cheap, but the quality of the work was excellent.
I hope I never have to use them for my C4S, but I highly recommend them.
Nice Jordan's. I would have tried to see how much a random orbiter could have buffed off first. I got one from Griott's garage years ago and it has removed some pretty bad looking marks. It's especially good at removing gunk caked onto the paint. Best save was after my wife hugged a painted fence post with a loaner.
Other concern is if this tiny claim ends up on a carfax report. Probably not. But that's a big reason to reserve claims for bigger issues.
As others have said, it looks like calcium residue from water dripping from the concrete structure above.
I would NOT attack that with a buffer or any kind of compound. It's hard residue. Go with the soft touch first. It will take longer but the underlying clear coat will thank you for the extra time you took. Aggressive buffing or rubbing will just leave swirls in the clear coat--especially since your car is dark.
Benihana's video was great. There are also products out there that take off water spots, so try one of those or vinegar and with some time and a little work, that should come right off.
A lot of people around here have well water and it's pretty hard. Every once in awhile I, or someone I know, leaves his car out while the sprinklers are on and we'll get terrible water spots when the sun hits the wet car. A little time and care is all it takes to get them off, before they harden.
Also, I wouldn't leave those stains on the paint any longer than I had to. The sooner you address hard water stains, the easier they are to get off.
If it were my 997 I'd talk with both a detailer and a body shop and get a few opinions. First step would most likely be a good detail - then go from there. Chances are it will buff out.
If not that airport might owe you some money!
