IMS Servicable? 1 tech says no, the other says yes
Hello ppeople, I just purchased a 2006 997 C2S Wednesday. I flew to Texas and drove it home to NY in about 30 hours straight minus a couple hours here and there sleep, had every option I wanted and I absolutely LOVE IT. I had a ppi done by a very reputable tech in Houston and he told me not to worry about ims failure for this model year and that to service it would be almost as much to rebuild because a complete breakdown was necessary which I already knew.
When I got home I went to my local ptech who seems very reputable from everything I read and has a pretty big operation going, he told me that he can do preventative maintenance on an 06 and is currently doing one right now on an 06 C4S. He showed me that guy's repair order, even had almost same mileage.Because of this he was able to give me a hard line price. Parts and labor $3500 for IMS with oil feed & RMS, $800 for a new clutch, and $400 for an AIR/Oil Separator.
I do believe I would not have a failure which is why I bought an 06 but I also didn't know this was an option and I'm still questioning if it is which is why I'm posting here. I am a worrier and I do believe I would sleep better knowing that this was done so, I would do it if it could be done.
He said it should take 10+ hours and I'm pretty sure he said he can do it without a complete engine breakdown. He seemed legit but I certainly don't want to be taking advantage of because of my IMS insecurity. lol
Does this guy sound on the level?
2. If the car was PPI'd by a reputable tec and the PPI turned out to be OK, there is nothing to worry (for now)
Conclusion, stop worrying, enjoy, and drive the damn thing if there is no tomorrow. The ptech back home seems to like big money and scare people, find a good one (or do it yourself) Good start is to buy this book https://www.amazon.com/Projects-Pors.../dp/0760344035 It has all the basics covered.
1. If you are a worrier, you should not have bought a 997.1
Anyone know someone good in Nassau County, Long Island?
Thank you for your input
That is so strange, to be advised to "monkey around" with the imsb on a 2006.
Imo, including everything I've read online plus my own personal experience owning an 06 c4s, you are good to go. Leave it alone
Perhaps if you're lucky jake Raby will contribute his opinion
Leave it alone unless you plan to track the car. Yes, there's a very "barbaric" way to do it without diassembling the engine. Basically remove the IMSB flange and use a big drill bit to drill and enlarge the engine case opening so the big bearing can be extracted (as is the bearing is bigger than the hole hence engine disassembly is required). It's insane if you think about the debris and what can go wrong.
If I had an '06, I won't do that even if you give me $3,500!
Take it to TKX Performance in Huntington station. Porsche trained and honest. As to the IMS "repair" if it isn't broken it is not in need of repair. Run away from that scenario. Good luck,
Gerry
btw, if /when you do need clutch do search on having IMS seal removed to improve splash lubrication
Gerry
Oil feed the current bearing without replacing it (splash lubrication perhaps)? Maybe this is his path. REPLACE the bearing? I'd be very skeptical for the dollars and hours he's quoting.
Ask him how he is going to REPLACE a larger non-replaceable IMS bearing on a 2006 007 without splitting the crankcase (i.e. engine tear down). Only the engines covered by the IMS bearing class action lawsuit are replaceable without tearing down the engine (early 2005 997's and all 996's). Unless he has invented some new method to REPLACE the bearing I don't believe it.
Ignore the reality of what "can be done" with the bearing for a second. You need to ask yourself the what "should be done" question first. Rear Main Seals (RMS) weep on the 997's. It's not a big deal, minor oil spotting on the floor if any, more likely just dirt accumulating where the engine mates to the transmission. It's not even clear if yours is weeping. If it was I'd only fix it if it was under warranty or if the clutch was bad and needed to be replaced since the labor overlaps almost entirely. Is your clutch bad now, slipping?
I would not under any circumstances drop the transmission or do any of the work related to dropping the transmission on a 2006 unless there was a problem, or if I was stripping the car down and turning it into a dedicated track car. So skip the IMS, RMS, and clutch preventative work. As for the AOS, did he put a manometer on the car and measure the crankcase vacuum? If the vacuum levels are fine then your AOS is fine. No need to replace it unless your engine was pulled and you wanted to do preventative work and save labor at the same time.
If it was me I'd save the $3900 and wait until the clutch goes before doing any of this work. And even then I'd only do the clutch and RMS for about $2200 total.
Yikes! 'Nuff said right here.
Gerry
Gerry
