Tracked and worried
Old 05-26-2016, 12:27 PM
Hella-Buggin'
Hella-Buggin''s Avatar
I installed the third radiator because I was getting oil temps up to 250. I installed the third radiator and temps hover closer to 235 ish. Occasionally they'll spike up a bit after a hard long session but I'm always aware of where the temps are and will back off if needed.
Old 05-26-2016, 03:02 PM
stronbl
stronbl's Avatar
On hot days, air temp 90+ degF and track temp 100+ degF, I push close to 250 degF with 3rd radiator in my 997-2. Maybe a little higher when the track has many turns and short straights, for example Thunder Hill West in CA. So I can certainly see 250-260 degF without 3rd radiator if you are really pushing it. Also I assume you are reading the oil temp from the dash and not from the ECU. I have found my data logging is a few degrees less than what I seem to recall the dash gauge shows (no digital readout in 997-2). Also do a Blackstone analysis a couple times per track season and so far no worries at all - additives and all remain stable.
From my experience, the oil temps you report are high but not unexpected and I don't think dangerously high.
No help on the white smoke issue.
Old 05-28-2016, 04:02 PM
M3 Defector
M3 Defector's Avatar
Third rad won't drop your oil temps that much. I have it and run around 245 on the track almost no matter what temp it is outside. Before the third radiator it would get up to 250.
Quick Reply: Tracked and worried
