Heat shield
Old Apr 18, 2016 | 10:16 PM
Jerrsnbrg's Avatar
Jerrsnbrg
Default Heat shield
I have 2007 997c4s and noticed my heat shield was loose. Only on one side. One of the bolts was actually gone and the other one was loose. My question is could these back out on there own or would my mechanic have removed these for the spark plugs. It has 60400 miles. The other side was completely tight. It seems weird that these would be loose to me. As far as I know no major work was done such as exhaust or anything else. If I hadn't noticcd this it could have come completely loose.
Old Apr 19, 2016 | 08:30 AM
Petza914's Avatar
Petza914
Depending on which heat shield you're referring to, it's likely it was removed for plugs and coil packs and not put back in correctly (hope the plugs were).
Old Apr 19, 2016 | 03:56 PM
cerbomark's Avatar
cerbomark
Ditto
I d be back at the service shop complaining. ( unless you are capable of just putting new screws in. ).
Old Apr 19, 2016 | 09:46 PM
Jerrsnbrg's Avatar
Jerrsnbrg
That's why I wanted to make sure that it was removed. The service was done a year ago and I was checking for a leak and noticed it.
