What is your "normal" start up methods on your 911?
Sir Thomas Lord of All Mets Fans
Originally Posted by RaidersR1
I've noticed the last couple days the OCD type behavior I have when I start up my C4S. Here is what I tend to do, every time;
1) Show a huge grin as I open the garage door, knowing what I'm about to do
2) Turn Key to check oil level
3) Push In Clutch
4) Take Car out of Gear
5) Start Car
6) Reach for the Sport Button to activate
7) Turn off PASM
8.) Activate iTunes for my TranzitBlu
9) Sit Back and relax while car warms up
10) Continue to smile during entire process
What do you guys or gals do?
3) Push In Clutch
5) Start Car
7) Turn off PASM
9b) Check out how awesome the driver looks in this awesome car in the rear view mirror.
T
1) get in
2) shut door
3) snap in seat belt
4) insert key
5) step on clutch
6) turn key, release clutch
7) check voicemail
8) check email
9) check craiglist app
10) type in 993 on craigslist app
11) surf for 5 min
12) realize i don't have wallet
13) un snap seat belt
14) open door
15) exit car
16) look in mudroom
17) look in office
18) look in bedroom
19) look in den
20) swear out loud
21) remember wallet is in jacket i wore last night
22) get wallet
23) enter garage
24) open car door
25) sit in buckle in
26) check tpms
27) make sure engine not overheating from idling too long
28) back out of garage
29) hear snap of charger cable i forgot disconnect
30) slam on brakes
31) swear out loud again
32) undo belt
33) get out of car
34) check charger cable did not damage door jam
35) coil up charger cable with charger
36) put charger away
37) back out again
38) call appointment and tell them i am running late
39) step on gas
40) smile and be happy to be alive
2) shut door
4) insert key
5) step on clutch
7) check voicemail
8) check email
11) surf for 5 min
14) open door
15) exit car
16) look in mudroom
17) look in office
18) look in bedroom
19) look in den
20) swear out loud
22) get wallet
23) enter garage
24) open car door
26) check tpms
30) slam on brakes
32) undo belt
33) get out of car
37) back out again
39) step on gas
1) get in 2) shut door 3) snap in seat belt 4) insert key 5) step on clutch 6) turn key, release clutch 7) check voicemail 8) check email 9) check craiglist app 10) type in 993 on craigslist app 11) surf for 5 min 12) realize i don't have wallet 13) un snap seat belt 14) open door 15) exit car 16) look in mudroom 17) look in office 18) look in bedroom 19) look in den 20) swear out loud 21) remember wallet is in jacket i wore last night 22) get wallet 23) enter garage 24) open car door 25) sit in buckle in 26) check tpms 27) make sure engine not overheating from idling too long 28) back out of garage 29) hear snap of charger cable i forgot disconnect 30) slam on brakes 31) swear out loud again 32) undo belt 33) get out of car 34) check charger cable did not damage door jam 35) coil up charger cable with charger 36) put charger away 37) back out again 38) call appointment and tell them i am running late 39) step on gas 40) smile and be happy to be alive
1) get in
2) shut door
4) insert key
5) step on clutch
7) check voicemail
8) check email
11) surf for 5 min
14) open door
15) exit car
16) look in mudroom
17) look in office
18) look in bedroom
19) look in den
20) swear out loud
22) get wallet
23) enter garage
24) open car door
26) check tpms
30) slam on brakes
32) undo belt
33) get out of car
37) back out again
39) step on gas
2) shut door
4) insert key
5) step on clutch
7) check voicemail
8) check email
11) surf for 5 min
14) open door
15) exit car
16) look in mudroom
17) look in office
18) look in bedroom
19) look in den
20) swear out loud
22) get wallet
23) enter garage
24) open car door
26) check tpms
30) slam on brakes
32) undo belt
33) get out of car
37) back out again
39) step on gas
Educate me on this. Where did you see it?
In the M96 motor, it was left-hand sweepers that caused oil starvation. And even then you had to be on true race slicks to generate enough G force for starvation to happen.
I get in, sit down and just look at the gauges for a second. Key in left hand, and just look.
Insert key, pause, then turn key to position 2.
Check the oil. Press pause on stereo if I notice it is not already.
Set phone to DND.
Change settings to Sound>Vibrate on Silent > Off.
Switch phone to silent.
Put phone in door pocket.
Pull car out of gear. (Clutch or no varies daily)
Start the car.
Smile at the snap of the start up exhaust sound against the closed garage door. Imagine how fun it would be to just stab the throttle - but remember there is a gentle old lady puttering around in her robe tending her roses across the street.
Press the garage door open button.
Slowly back out of the garage and stop, listen to the rumble. Close garage door and observe the property. Gate closed? Side gates latched? Anything different this morning?
Slowly back out. Angled just right so as not to scrape my chin on the steep driveway-roadway transition.
Idle it in reverse. Stop and last look at the house.
Locked up tight?
Imagine work for one second. Sigh.
1st gear roll quietly. 3rd house down, 2nd gear. Roll quietly.
Always leave my neighborhood at nearly idling (no wake zone) - always around 17 mph.
Oil warms up by the time I reach the freeway.
The only thing that really changes from that sequence is if I need to add oil, and the time of day that I leave.
Set phone to DND.
Start the car.
Locked up tight?
