What do I know, but isn't peak torque/hp several hundred RPMs below redline, so what would be the point of bouncing off the limiter (versus shifting to a more apprpriate gear)?
Your torque is multiplied by the transmission. A higher rpm in a lower gear nets more wheel-torque than the next higher gear at a lower rpm. Put simply, if you shift early, you might be in a "better" torque band on your dyno curve, but it will still be less power to the wheels because you are in a higher gear.
When the time delay for the shift is considered along with the HP drop, NOT shifting is sometimes the correct thing to do, even if it means potentially bouncing off the rev limiter.
There are also times when upshifting is not the appropriate thing to do because your hands are otherwise occupied.
And, though admittedly I can count the number of times it has happened on one hand, bouncing off the rev limiter in fifth is the less terrifying option vs. manning up and trying to ****** 6th...
It's better to be realistic, and approach life that way. So, while being technically correct is nice, being realistic results in things such as rev limiters.
You can exceed redline on a downshift and be fine, if it's mild and in range. So, it looks like the use of over revving in this thread needs to be better defined.
Downshift over rev = spinning the engine past its design limits, according to previous posters, but this isn't the best and most consistent use of over rev
Over rev report = captures even those ignitions in ranges which are safe and could be from a slight run past red line (thanks rev limiter) and downshifts which land in a gear which over revs the engine, including ones that land in safe and unsafe ranges.
A blown downshift can trigger an over rev ignition count and be harmless if it's in the lower range.
You can also use the hour indication to get an idea of whether have anything to worry about (when you're checking out a potential purchase)... (Note:ignition ranges for my '99 are much more simplistic with just 2 ranges; later cars that have several additional ranges.)
If the car has 2,000 operating hours and shows 25 range-2 ignitions at 750 hours, you have a pretty good idea that the previous owner wasn't consistently blowing shifts and endangering internals, and I would also be willing to believe that in the intervening 1250 operating hours any issues caused by the over-rev would have made themselves known by now.
On the other hand, if you see thousands of range 2 ignitions and the most recent were just one running hour ago, it's wise to be skeptical.
Keep in Mind, his Range 2 is different than our range 2. In a 997, range 2 is simply bouncing off the limiter with a bit of gusto.
Just to clarify the mention of ranges for 997. GTS and X51 C2/4S engine's fuel cutoff is 200 rpm higher than standard C2/4S and is in Range 2. So a GTS and X51 range 2 is hitting the redline/fuel cutoff and Range 1 is simply just high revs before rev cutoff.
